    Nov 2019
    125k btu hot Dawg code 7 flash!!
    Brand new unit, high altitude kit installed.. it runs for about 15 min then cuts out ,, flashes the 7 code ,, Any ideas ?? incoming propane pressure is fine..
    Jun 2014
    Dover, DE
    What does your service technician suggest to fix the problem?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Athens, Ohio
    Site rules prohibit giving advice for DIY.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Jul 2018
    Wisconsin
    • 5 Flame losses during one heat cycle
    • Ignition Re-Cycle - The control will re-cycle
    up to 5 flame losses (4 re-cycles) within a
    single call for heat before going to lockout.
    The LED will flash “7” during this lockout.
    That is what the flash code means. Site rules prohibit DIY help. There are other sources online for help. Good luck
    Moved to AOP.
