Results 1 to 9 of 9
    Nov 2019
    Modine Garage Heater Installation Advice
    I have purchased a Modine 60,000 unit to heat my garage. There are a couple of items I could use some help on:
    1. I am in an earthquake zone. I am aware of the required use of the flexible gas line and shutoff valve, but I'm wondering if there are any earthquake requirements on how I mount the heater? The options I see are using the Modine ceiling mount brackets or using threaded rods suspended from the ceiling? Any tips here?
    2. I didn't really want to vent horizontally, but I think that is where I am going to end up. The reason I didn't want to is because the vent will be on a very visible side of the house. But if I roof vent, it would go through unconditioned space and I really don't want to deal with the condensate that will run down the vertical into a drain tee. Am I on the right track, or should I look harder at a roof vent?
    Thanks very much in advance! Great forum here ....
    Jun 2014
    Dover, DE
    Is your installing company unable to provide this information? They should be able to tell you how to properly do everything per code.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Nov 2019
    Truth be told, I live in a VERY, VERY competitive housing area of the country. I have called 7 HVAC/Plumber contractors and no one is willing to do a job this small (and I live a little remote from town). So, I will have to install myself. I am just doing the research to ensure I do it right.
    Jun 2014
    Dover, DE
    Sorry, we cannot be of help to DIY projects.
    Nov 2019
    That's interesting, but I seem to remember that about this forum. No worries, there are many more.
    Southold, NY
    Quote Originally Posted by thompsdw2 View Post
    No ones willing to install equipment YOU purchased?
    There are ways to minimize/eliminate condensation in a situation like yours.
    A qualified installer would know how to do that.
    If you are venting horizontally, you likely will need stainless steel flue pipe. Some of these garage heaters are no longer allowing double wall flue out the side wall as it isn't tight - not that it really matters in a garage.
    SW FL
    AHJ ?
    Google
    1. TOLCO Seismic Restraint Systems Guidelines
    2. SMACNA Seismic Manual
    ____ and your National, State, County, LOCAL Building Code(s), as applicable.
    Quite difficult to provide Any specific guidance
    _ " … I am in an Earthquake Zone …" ; " … remote from town …"
    _ _ _ presume somewhere in the Western Hemisphere
    … _ _ _ Alaska, WA, OR, CA, UT, NV, Missouri, VA, SC, Cuba, Chile, Argentina, …
    There are lots of small towns in 6 Western, a few Eastern US states + other global locations.
    Designer Dan
