Page 6 of 8 FirstFirst 12345678 LastLast
Results 66 to 78 of 92
  1. #66
    Jul 2018
    Las Vegas
    Quick question on these valve gaskets and plates
    Does it go king valve black gasket, metal spacer green gasket black gasket sandwiched all together?
  2. #67
    kansas
    I’ve used one or the other if I understand you correctly. If using green make sure you lightly coat if oil.
    Honeywell you can buy better but you cant pay more
    I told my wife when i die to sell my fishing stuff for what its worth not what i told her i paid for it
  3. Likes Wskunza liked this post.
  4. #68
    Jul 2018
    Las Vegas
    Quote Originally Posted by crazzycajun View Post
    Iíve used one or the other if I understand you correctly. If using green make sure you lightly coat if oil.
    Oh looked like the las compressor had it like I describe valve black, metal spacer,green,black just making sure.
    So I have the freedom here of either green or black?
  5. #69
    kansas
    As long as there one gasket per mating surface you will be fine as long as the mating surfaces are clean and tru.
  6. Likes Wskunza liked this post.
  7. #70
    kansas
  8. Likes Wskunza liked this post.
  9. #71
    Mar 2015
    Medford, N.Y.
    Just one gasket is needed.
  10. Likes Wskunza liked this post.
  11. #72
    Jan 2010
    Also for us terminology freaks, that's not a "king valve" it's a service valve. The only place you'll have a king valve is on the outlet of a receiver.
  12. #73
    Jan 2010
    and yes Copeland is moving away from the green type gaskets to the metal ones. Which sure makes removal much easier down the road.
  13. #74
    kansas
    A good friend and colleague called all valves king too. Drove me nuts now I’m to hung over to care
  14. #75
    Southold, NY
    Cheers
  15. #76
    Jul 2000
    Guayaquil, EC
    Little K bodies?
    Iíd like to see that, didnít see anything on Emersonís site for them.
    Quote Originally Posted by Olivero View Post
    This is the model.
    LACA-032E-TAC-800
    Looks similar but I don't think the models similar, it's quite large.
    Copeland (USA) doesn't have a body cooling fan kit for the K-body, however they do offer one in Europe for their DK-body Copelametic which is the same compressor.
    https://climate.emerson.com/document...gb-4265872.pdf
  16. #77
    Jul 2018
    Las Vegas
    Semi Hermetic compressor without chilled water loop
    So, UPDATE! As to the why this went out,got system back up and running unit head pressure keeps creeping up and up I have a condensing temp of 126+ itís like the water pressure regulator isnít either supplying enough water or some other issue of cooling the condenser. Condenser coil is piping hot data to follow
    P.S. yes I looked to try and regulate the water but all I could find is a manual override flush.
  17. #78
    Southold, NY
    You need pressure and temperature readings on the water in and out.
    Got a pic of the condensing unit?
