Results 1 to 8 of 8
    Virginia
    Why 2 ports on draft inducer switch
    102998-01 is the switch part number
    0.65 WC
    I worked on a Ducane/Lennox 90 % furnace
    Its cutting out flame after about 5 minutes , gives a code 3 ( lost inducer vacuum signal ) then comes back on .. repeat
    I have a switch on order because I checked trap , flue , hoses
    Well it has 2 hoses , one coming off inducer , and other coming out of condensate drain box thingy , both connect to inducer switch
    Why ?
    May 2019
    Central, IL
    Differential , if everything is clear , I suspect partially plugged/clogged secondary
    Virginia
    Post the model number of this unit if you can.
    Also, send me an email, and I will get a pressure switch pdf off to you.
    Jun 2012
    Northern NV
    Has two PS on it, right? One proving the inducer and the other (2 ports) for blocked secondary/plugged drain..
    Had a Ruud that about a thousand bees committed suicide in and ended up in the condensate trap....
    A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.
    ― Robert A. Heinlein
    Virginia
    I don't see the model anywhere , they must have forgotten to slap a sticker on it .
    But its a Lennox with Ducane badge
    Virginia
    replaced switch and she runs
    You cant really see , but both red and blue hoses go to the switch
    Nov 2019
    VA
    Sounds like you have it. next Time, hook up a duel port and see if the switch is making. This can eliminate replacing a good switch. ��
    Mar 2010
    Arnold, Mo
    I just repaired a Lennox 90% that looks just like your Ducane. The model was ML193UH090XP48C-05. I thought the same thing about the 2 ports. I guess the 2nd port is a blocked drain switch.
