Results 1 to 13 of 14
    May 2019
    Central, IL
    American standard not lighting all the time
    Hi all, long time lurker first time posting.
    Have an aux080r942v2 that has the update kit installed. New board, inducer, harness.
    Replace igniter 3 years ago with a hot rod , all good until today.
    Igniter glows red hot, gas valve opens , can hear gas , only lights once about 10 trys.
    Cleaned burners, no change.
    Tried 3 different style of igniters, no change.
    Incoming gas psi good, 7.9" natural gas
    Manifold low psi was 2.2, hi 3.5
    Adjusted low psi to 3.5 seemed to help but still doesn't light every time.
    Can light with lighter no problem , definitely not plugged oriface .
    This one has me stumped, any suggestions?
    May 2018
    Santa Clarita, CA
    Perhaps the position of the igniter.
    Virginia
    For some reason the gas mix isn't blowing by the ignitor well
    Either tilt the ignitor , or figure out why the gas mix could have changed its path
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by Snapperhead View Post
    If you have not done it yet run an orfice bit thru the orfice, a white chalky corrosion buildup around the hole can occur and cause this scenero.
    Oct 2002
    Plano, TX
    Check gas pressure. Don't assume if it worked last year it isn't a pressure problem
    Aug 2009
    Beatrice, NE
    Did yo check igniter voltage?
    May 2019
    Central, IL
    Thank you all for the replies,.
    I did play with the igniter position with different igniters.
    I have checked checked and adjusted the gas pressure.
    I will check the orifices with proper bit.
    When it does light the igniter is fully in the flames.
    I did not check the voltage to igniter for some reason.
    I will check orifice and voltage and let u guys know.
    Thank you agian
    Southold, NY
    What was the gas pressure?
    May 2019
    Central, IL
    Replaced circuit board and igniter under advice from my AS service rep.
    Problem solved.
    Seems as though igniter warmup timing had shortened somehow(bad board).
    Thank u again for the help.
    Matt
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by Stoichiometric View Post
    Problem solved.
    Matt
    You didn't time the igniter warm up????
    Just kidding!
    Virginia
    Quote Originally Posted by BNME8EZ View Post
    Just kidding!
    probly need atleast 50 mississipppi's
    Aug 2009
    Beatrice, NE
    Nope, on those only about 20.
    May 2019
    Central, IL
    17 to be exact, the original board seemed to be adjusting the warmup time by a few seconds each time.
    I thought that was normal for older trane/as which is why I didnt recognize at first.
    Turns out it was the older 80 volt ignition systems that varied the warmup time, they dropped that feature on the update kits and all 120 systems
