Results 1 to 13 of 15
    Denver, CO
    Cutting Copper With an Angle Grinder
    I've got a big job tomorrow where I've got to cut out 1 1/2" in some close quarters and propress in some new valves. I hate using a sawzall it leaves a rough edge and causes too much vibration. I want to use my angle grinder with cut off blades. I think it will work out very well but I was wondering if anyone else has tried doing this?
    New Jersey
    The only time I have used a cut-off wheel is for demo. It does cut, but it does leave a burr on the pipe.
    Sent from my ASUS_P00J using Tapatalk
    Jul 2011
    DFW, TX.
    Done it before and will again. Only worry was/is the fillings but if its b4 the suction drier I think it'll be ok.
    Sent from my LG-G710 using Tapatalk
    Denver, CO
    Quote Originally Posted by CEAS-AC-TECH View Post
    It's on a heating loop, thanks for the input guys.
  5. Likes CEAS-AC-TECH liked this post.
  6. #5
    Nov 2010
    kentucky
    Chain pipe cutter if you have the space.
  7. #6
    Nov 2011
    East Side
    I would prolly never do it on a refrigeration system. Unless I had a filter downstream.
    On a hot water loop, it shouldn’t matter.
    A cutoff wheel seems to produce more debris than a saw. Plus you’ll have to clean the cut edges before putting in a propress fitting, etc.
  8. #7
    Jul 2018
    Wisconsin
    Portaband if it will fit.
  9. #8
    May 2018
    VA/DC
    heating loop. roll on
  10. #9
    Jan 2010
    Sea to Sky
    Close quarters tubing cutter. I have one that does 2 5/8" OD.
    Sent from my SM-G965W using Tapatalk
  11. #10
    Jul 2018
    Wisconsin
    Gotta get me one of these
  12. #11
    Jan 2010
    Sea to Sky
    That is the one I have....sorry apparently goes to 2 3/8"
    Quote Originally Posted by Spitz View Post
  13. #12
    kansas
  14. #13
    Denver, CO
    Okay for water this is the way to go, no vibration then you have a grinder to bevel the edges really nice and fast. But 71Chops made a very good point. There were way too much fine particles in the line afterward. I would never do this on refrigeration. I am going to buy that chain cutter that crazzycajun posted though.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
