    Nov 2019
    Daikin mini-split heat pump fan
    Recently had two units installed: 1 x 15,000btu on our main floor, and 1 x 12,000btu in our bedroom.
    Today I noticed the fan on the larger pump has been running continuously. Both pumps are set to 18oC, and the fan on the smaller pump has only been running intermittently.
    Both pumps are set to heat mode with auto fan selection.
    Today’s weather is on the mild side at 5oC, and I was wondering if that could be contributing?
    Thanks for your time!
    Mar 2018
    Chico, Ca #StateofJefferson
    What's the model number of the head and condenser?
    Southold, NY
    What does the installing contractor say.
    Mar 2018
    Possibly a setup issue, those heads can be setup to read the airtemp from the remote, or from a sensor in the head or a combo. If it's not reading room temp solely from the remote it will run the blower 24/7 as I recall
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
