Results 1 to 7 of 7
    Nov 2019
    2 thermostats for 1 fan
    hello.
    I would want to run a ventilation fan in a small room at 1/2 speed all the time except between about 75 to 80 degrees where i want 1/1 speed, when the temperature exceeds this temperature, a separate cooling unit will kick in and the fan should go down to 1/2 speed again.
    Can this be done with 2 thermostats in parallel to 1 transformer with 2 switches?
    Edit: should be done in a easy way without PLC or DUC
    Dec 2006
    Vancouver, B.C.
    Quote Originally Posted by lovetofly View Post
    hello.
    We can’t provide DIY advice on how to do it but what you are asking to do sounds possible with one thermostat, one transformer, and some relays. The setup would differ depending on the wiring configuration that the motor requires.
    In short, the answer is most likely yes.
    What is PLC and DUC?
    Quickly, I must hurry, for there go my people and I am their leader!
    Mar 2016
    Dayton Oh
    Logic controls. think "if/then and/or" type stuff. similar to building HVAC controls. just different forms of language.
    kansas
    It can be done easier with a multi speed fan and a relay and one tstat if I understand you correctly
    Dec 2006
    Vancouver, B.C.
    Quote Originally Posted by jbhenergy View Post
    That wouldn’t be necessary
    Mar 2016
    Dayton Oh
    Quote Originally Posted by thatguy View Post
    I agree, I was just pointing out what plc controls were since you stated you had not heard of them before.
    That is all
    Oct 2011
    Chicagoland Area
    2 stage temp control and a couple relays
