Results 1 to 7 of 7
    Nov 2019
    Now cold basement
    I don't think this is a unique question but I can't find info by searching.
    I live in Maine in an old farm house with moderate insulation. I have to mini splits in the house in main area and they work fine. I was thinking of adding three more for another two story part of the house.
    I have an efficient oil fired furnace which is used in that part of the house now. Of course when the furnace is on the basement is kept warm also. Thats where the water pipes are and I also have a heat pump water heater down there.
    My question is if I install heat pumps and the furnace is not used will my basement be so cold that the pipes might freeze and of course the water heater won't have as much warm air to be efficient. I have 6 people with this problem.
    Should I wrap the pipes, add heat some way. Heating the basement would be expensive and wipe away any savings. Some help would be appreciated.
    Jan 2012
    Missouri, USA
    Add another mini split head down there.
    Jan 2012
    Broomall, PA
    If you’re in Maine, and your oil burner is efficient, you should be using that over the mini splits when the temperatures are gettin that low.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Quote Originally Posted by islandguy5 View Post
    This and the cost of a heat pump water heater just don't make sense to me in justifying them.
    Nov 2019
    Quote Originally Posted by pacnw View Post
    I guess I should have mentioned that I live on an Island. Oil suppliers, electric, propane, transportation everything is much more expensive and lately we our being gouged by many of these suppliers.
    I will be installing ground mount PV system but first I have to get all expenses figured out.
    Jul 2001
    Fairfield and NewHaven Counties in Commecticut
    Add another mini to the basement then.!
    Quality and Value Service and Repair
    Southold, NY
    that heat pump water heater is a refrigeration system in the basement.
    You'll need a heat pump with roughly the same capacity as the heat pump water heater!
