Results 1 to 7 of 7
    Jun 2019
    Nameplate 5 ton LRA 20A -- can this be real -- sizing a generator
    I'm looking at residential standby generators that would power my 5 ton HVAC. It's a newish model very high SEER, digital controlled scroll compressor.
    My generator vendor has calculated sizing using a six fold multiple of RLA. Reading other threads this is a pretty typical assumption for inrush current LRA calculation.
    But...
    The nameplate on my outside unit states RLA 20 AMPS / LRA 20 AMPS. Is this LRA value usable for sizing a generator? Obviously a big difference between 20 AMPS and 6 X 20 AMPS.
    Mar 2018
    Chico, Ca #StateofJefferson
    This is an inverter system I take it? If so, I would thing that its accurate but you need to factor in the amp draw of the airhandler, any supplemental heat strips, etc as well. I dont size generators so take it for what this is worth, but inverter compressors really dont have any inrush as they use a soft start on the compressor where it ramps up to its requested speed over the course of a minute vs going from 0-100 in a quarter second
    Jun 2019
    Thanks makitcold it is an inverter system. I trusted the nameplate info but I'm surprised not to have seen this benefit of digital controlled inverters mentioned around the web on generator sites. It can have a BIG impact on generator sizing.
    Southold, NY
    Quote Originally Posted by MikeBW View Post
    Be more concerned with the Gen putting out a clean sign wave AKA Clean power.
    Computers don’t like dirty power!
    EXACTLY!!!!!!
    I have seen many motors and controls rendered useless on generators that either were never set up properly, undersized and/or delivered dirty power.
    Personally, if this is straight a/c, I would not use it on a generator. Live through the time on the generator without a/c. Now if the indoor equipment is computer controlled, ECM blower motor and/or inducer motor, you need to make darn sure you get something from the installer in writing that it won't be an issue.
    SW FL
    Quote Originally Posted by pacnw View Post
    EXACTLY!!!!!!
    Live through the time on the generator without A/C.
    ____ ABSURD IN FLORIDA.
    ___ NO POWER FOR A WEEK OR TWO
    … … … PEOPLE DIE
    + VIOLATION OF RECENTLY ENACTED FL STATE LAW for ANY Assisted Living Facilities (ALF)
    ________________________________________
    Designer Dan
    inverter generator? don't know anything about gens. but my honda 3000ie I think it is does the same work a 5k work horse would do and is a hell of a lot quieter. don't use it on the house though.
