Results 14 to 15 of 15
    SW FL
    Thumbs up TRANE AHRI 7793615 _ CLG LV TEMP 53.4'F
    Quote Originally Posted by mkwyche View Post
    Hi,
    I currently have a system from 2003.
    Current system spec are:
    - Outside unit Trane XR12: 2TWR2024A1000AB
    - Inside unit Trane TWE031E13FB1 (2.5 - 5 ton)
    I'd like any thoughts on the two options and
    if going up to 2.5 on the outside unit is the correct move given the current
    outside unit is just 2 ton.
    My home is 1346 Sq Ft and I live in Climate Zone 3.
    Thanks in advance for all your feedback.
    __ SPECS __
    TRANE XR17
    ______ HEAT PUMP, 2-TON, 2 STAGE
    or Equal
    __ % R.H. Control
    _ An A/C SYSTEM needs to operate > 9 hours / day
    for 5+ months in Climate Zone 3
    Leaving cooling coil temperature { clg LDB }
    is required to be < 54'F to properly handle humidity.
    / ____________________ maintain < 52% R.H.
    __ Calculated DT > 21'F _____ .:. Do NOT upsize coil.
    [ 77.0'F - 53.4'F = 23.6'F }
    ________
    ZIP _ _ _ _ _ <---- needed to determine CDD ... Cooling Degree Days
    $0.1 _ _ / kw-hr __ needed to determine Operating Cost
    Operating time is calculated based on Local CDD.
    Designer Dan
    SW FL
    S.E. US _ non specific
    OPERATING COST
    ______________ GENERIC
    Basis: A Very Low utility rate
    … … … i.e. Jackson, MS
    A/C System may operate on 1st (Low) stage > 80% of the time.
    ______ … … High stage may be needed at > ~ 89'F
    Designer Dan
