Results 1 to 13 of 35
    Aug 2019
    Three way ball valve
    Hello good people.
    I'm trying to join two chest freezers to one compressor. The capacity of the compressor can only support 1 freezer. I need a "3/4 inch three way ball valve" between the freezers and the compressor so that I can alternate it's operations manually.
    Unfortunately, the 3way valve I saw wasn't 3/4" all through. The fitting ends are 3/4" but the inner diameter is reduced and becomes narrow inside.
    See picture attached.
    Please, how can I get a true 3/4" brass 3 way ball valve?
    Thanks.
    Sent from my S61 using Tapatalk
    Apr 2003
    Maple Grove, MN
    You do know that chest freezers are critically charged systems that operate on a minuscule amount of refrigerant, right? You also know that that isn't a refrigeration ball valve, right?
    Unless your name rhymes with "Noodlehead Bikey", I give this about a zero percent chance of working.
    If at First You Don't Succeed, Skydiving Is Not for You.
  3. Likes GoCougs liked this post.
  4. #3
    Jan 2010
    Quote Originally Posted by Ahmedgee View Post
    Hello good people.
    Thanks.
    Seriously
  5. #4
    Aug 2019
    Quote Originally Posted by ammoniadog View Post
    Thanks for the info. But pls anyway out?
  6. #5
    Jul 2000
    Guayaquil, EC
    What you're looking for is a full-ported, three-way refrigeration ball valve...like this:
    http://muellerrefrigeration.com/prod...l-valves/3-way
  7. Likes Ahmedgee liked this post.
  8. #6
    Mar 2015
    Medford, N.Y.
    How big are these chest freezers? They require a 3/4'' ball valve?
  9. #7
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by TechmanTerry View Post
    The OP has a previous thread about his "chest freezer": https://hvac-talk.com/vbb/showthread...-Refrigeration
    It's 15 ft x 15 ft x 5 ft high.
  10. #8
    kansas
    I had no idea muller made those, have you yourself used on or seen them used? Or should I say I’ve seen full port, but not in that situation.
  11. #9
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by crazzycajun View Post
    No, I've never seen one either, but I noticed that Meuller was making them a while back when someone else on here was looking for 3-way valves. I seem to recall seeing a Sporlan modulating three-way valve in their literature recently too.
  12. #10
    Dec 2014
    New Mexico
    A tee and a couple of ref. ball valves good to go.
  13. #11
    Aug 2019
    Quote Originally Posted by icemeister View Post
    Exactly! Thanks sir.
    I studied electrical but I fall in love with refrigeration. It's interesting.
    I just like to put my ideas in practice.
    U are always ahead.
  14. #12
    Jul 2018
    Wisconsin
    Sporlan makes a 3 way that is activated by a solenoid.
  15. Likes Ahmedgee liked this post.
  16. #13
    kansas
    Quote Originally Posted by Spitz View Post
    I’ve seen and used them for heat reclaim
    https://sporlanonline.com/literature/30/SD-114.pdf
