Results 1 to 13 of 33
    May 2017
    richmond virginia
    Recycling gone wrong
    What the hell
    Apr 2003
    Maple Grove, MN
    What's the main issue here? At first glance it appears like you don't know what a concentric vent kit is or how they work.
    If at First You Don't Succeed, Skydiving Is Not for You.
    May 2017
    richmond virginia
    Quote Originally Posted by ammoniadog View Post
    Thats what i thought at first but its not. Its just 2" pvc tied together at the Y.
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by kennybaker2014 View Post
    Sorry I blew up at you.
    May 2017
    richmond virginia
    Its all good ammoniadog for 3 reasons
    1) i probably should have stated that its not what it looks like
    2) because if i didnt know about concentric venting you would have learned me something
    And 3) ammoniadog is a badass name. LOL!!
    Athens, Ohio
    It does not look like a 2” tee to me, either. Does the furnace run at all with that venting.
    I have encountered concentric kits where the installer did not glue the inner 2” exhaust piece at installation. The furnace ran fine with the upper door off as I was testing it, but it shut down when I put the door on because it was recirculating the exhaust into the burner compartment.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Jan 2010
    Looks like a concentric from here
    Mar 2016
    Dayton Oh
    I’m going with all the others that it looks like a vent kit to me as well.
    Here is standard y
    https://www.lowes.com/pd/charlotte-p...B&gclsrc=aw.ds
    Aug 2015
    Buffalo,NY
    So is there no 2” inside of the 3” then? Assuming the flue is on the left with the fernco fitting then it’s piped into the concentric wrong also.
    May 2017
    richmond virginia
    Quote Originally Posted by Metalman0880 View Post
    Correct. There is absolutely nothing inside of the piping. I got called there because the furnace wasn't working. Get there and take the cover off to look at safeties, flame sensor, etc. Find everything pretty normal. Push in door switch and on it comes. Tape the switch closed and watch for a few minutes. Eventually i go to close door and it immediately goes out. I open it up and push switch and everything's fine again. Only when i close door is it not working. Check airflow=seems good. On to check venting for debris from outside. Wait! Whats this? No inner piping? Just regular pvc all the way thru? Hmm
    Athens, Ohio
    Now I can say it. “Why is it always a Goodman?”
    May 2017
    richmond virginia
    not to mention this is a downflow in a closet at the back of the house with the door always closed and no filter
    Also the flex gas line runs through the cabinet all the way to the gas valve.
    Jan 2010
    Why would pulling the blower door off a sealed combustion change anything.
    Is it not a sealed combustion unit ?
