Thread: HRV and furnace
    Aug 2018
    HRV and furnace
    Greetings,
    The design for my new build required 2 separate HVAC systems hence 2 HRVs. I've decided to have hydronic installed for in floor heating on all floors and I would have never imagined that it is capable of providing enough heat for a comfortable temperature inside the house. Not sure if it's a good idea but was hoping there is a way for HRV to work independently and not rely on furnace fan as that will spare me buying two new furnaces which will basically sit unused if I will heat the house with hydronics. Is there a better solution to this instead of purchasing 2 furnaces?
    Will you still have central cooling?
    Aug 2018
    Yes, I will.
    Then you’ll still use 2 air handlers.
