Results 1 to 2 of 2
    Nov 2019
    Confused Can't find the right zone damper actuator replacement
    I'm trying to replace a simple 2 wire, spring-return, zone damper actuator/motor, but the recommended replacement part, honeywell 847D, has entirely different mounting connections and doesn't fit at all. It's the equivalent of trying to plug 2 female ends together.
    Here's some quick pics showing the problem: imgur.com/gallery/Vi8ceJY
    Sorry, new user so it wont let me make that a proper hyperlink.
    I can't for the life of me find a replacement actuator with that kind of mounting/bracket connection. Is it just obsolete and out of production?
    My other options are to replace the whole damper or try some kind of retrofit.
    Athens, Ohio
    Site rules do not allow giving advice for DIY. A technician can probably figure out what you need.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
