Results 1 to 8 of 8
    Jul 2018
    Today's Hack Job
    I found this on a job today. What is code in your area for furnaces on top of floor drains? I told the owner it was unsafe, labeled it unsafe, and left it turned off.
    Southeastern Pa
    You probably have to lift that up and sit it on a sealed return plenum so as not to draw in any gases from the floor drain.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2019
    Oklahoma home its in the name
    Wow. For some reason that reminds me of a local restaurant here that I noticed the bathroom stunk and I saw somebody had coated the floor drain in Silicon. I'm pretty sure they did that because nobody knew to put water down the drain every now and then.
    Sent in a state of increasing entropy using Tapatalk
    Mar 2018
    Kansas Flatlands
    Could you not have put a piece of metal over the drain under the furnace to at least keep the heat on???
    Jun 2019
    So Cal
    Quote Originally Posted by timebuilder View Post
    But then how would you drain the water out?
    Jun 2019
    So Cal
    Quote Originally Posted by theoldscroll View Post
    Of course, but there is no money in that... I am sure Money is the reason and not safety...
    Bedford,Ohio
    IF it is a condensing furnace and it has A/C, wouldn't the condensate keep the trap full and then there would be no sewer gases?
    Southeastern Pa
    Quote Originally Posted by BuildingMech88 View Post
    Spacing .
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
