Results 1 to 7 of 7
Thread: duct design ?
    Mar 2016
    Dayton Oh
    duct design ?
    PD of wet coil =.27
    PD of 4" honeywell f100 merv 11 filter cabinet = .23
    my math tells me i have 0 ASP for my duct.
    WTF.
    suggestions to go from here. C width coil vs B width?
    Athens, Ohio
    How about a MERV 8? I have found that can make a difference.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Jul 2019
    Oklahoma home its in the name
    I don't know your situation but if there's like two returns off of the return plenum then you could put two filter racks to reduce the static. Or my favorite is to use multiple return filter grills. The only problem is that usually restricts you to either one or two inch filters.
    Sent in a state of increasing entropy using Tapatalk
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by R600a View Post
    Filter grills are restrictive be careful there
    Jul 2019
    Yes but if you have multiple you can get the static pretty low by having more filter area.
    Mar 2014
    Grand Blanc
    Why not pick a less restrictive filter? I use the following budget to pick my filters, coils and size ductwork.
    Coil PD max 2.5”
    Filter PD max 1.5”
    Supply Duct .05”
    Return Duct .05”
    If I’m limited on ductwork then I’ll pick a less restrictive filter or over size the coil cabinet.
    Mar 2016
    Dayton Oh
    Actually everyone, I just can’t read......
    If I could read, I would have seen that running a 16x25 at 1200 cfm then my pd is like .175 across the filter.
    Back to the calculator......
    What a dumb dumb.
