Results 1 to 2 of 2
    Nov 2019
    C Wire not connected
    Hi, I just moved into a new home and was trying to connect my Ecobee thermostat. I know it requires a C-wire. I found the wire wrapped around the others in the previous thermostat, which didn't require one. When I connected it to the Ecobee, however, it did not show the display. Assuming then that it was an issue of the C-wire not being connected, I went into the attic and looked at the wiring. Sure enough, the blue wire is there, bit wrapped around the others, not connected. I looked where it should be connected and found that there is a second red wire connected there. My question is, can I connect the blue wire (C-wire) to the same terminal that the red is connected to? It seems like I should be able to.
    Ecobee actually makes a kit which doesn't require a C wire however... what you are asking is DIY and this site can't give DIY directions.
    Ecobee is a great thermostat and has wonderful customer support. They can assist you there.
    I will need to close this thread as it is not allowed.
    Admin
