Results 1 to 6 of 6
    Nov 2019
    Questions regarding different hp blower motor consuming power
    On internet, this website displayed where a HVAC tech replaced a 1/3 hp blower by a 3/4 hp blower and owner started asking questions about power consumption tripling.
    I saw numerous responses but none telling that same rpm higher hp motor will not triple current but current consumption will be almost same as work done is same.... Same blower, 115V supply, same rpm fir both motors. 3/4 Hp will have some unnoticeable higher power consumption but not 3 times.
    Athens, Ohio
    Do you have a question?
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Southold, NY
    Quote Originally Posted by mswaldia View Post
    3/4 HP will burn up quickly!
    Nov 2019
    Would like to know more on 3/4 hp failing earlier. What can be the probablecauses?
    Southold, NY
    No Load...…..
    the electrical energy will produce more heat and less work.
    Add to that the extra starting torque will tear that squirrel cage to bits!
    Southeastern Pa
    And boy.... that really makes those squirrels angry....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
