+ Reply to Thread
Results 1 to 7 of 7
Thread: Wiring help with a freezer
    Apr 2018
    Here is the wiring diagram from a Kenmore upright freezer. The temp control is defective but it’s obsolete. It appears that two sets of contacts aren’t necessary. Can I just get a universal freezer control and connect the red and blue wires together on one terminal? Thanks in advance.
    kansas
    What’s the contact rating on the universal controller?
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Do those contacts actually always close together? Because it doesn't make sense to me.
    Sent in a state of increasing entropy using Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    Apr 2018
    The amp load of the whole thing won’t exceed 5A so probably any control would work. I don’t know for a fact that the contacts close and open together. Black-to-red is only open in the off position. Black-to-blue never closes and that’s the problem. I jumped the black and blue and the freezer runs which raises the question “what does the red wire do?” I can’t really see a reason for it except to notify the “electronic module” that cooling is being called for. Could it have something to do with the built-in temp alarm?
    Jun 2006
    It will work just fine.
    Oct 2011
    Chicagoland Area
    Use a SPST control to energize a DPDT relay. Not sure why there are 3 power sources going into the module.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Jun 2006
    Lolely to indicate when the comp is running, when defrost is on , and to power led temp read out is my guess
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
