Page 4 of 4 FirstFirst 1234
Results 40 to 47 of 47
  1. #40
    Jul 2011
    DFW, TX.
    Quote Originally Posted by HE>I View Post
    Morning! Headed to the job now. Any advice for the start up sequence?
    Run through the ops manual. Piece of cake. Run through all the settings. Hallar at @DAD for the pro membership then you will get more responses. Cant do much in an open forum.
    Sent from my LG-G710 using Tapatalk
  2. #41
    Oct 2015
    Chino, Ca.
    Quote Originally Posted by CEAS-AC-TECH View Post
    Pretty stoked, just got my pro membership!
  3. Likes CEAS-AC-TECH liked this post.
  4. #42
    Jul 2011
    DFW, TX.
    Now ask this thread be moved to the locked forums
  5. #43
    May 2014
    Bay Area California
    Or merge the two threads.
    I do a triple evac with nitro to remove non condensables.
  6. Likes CEAS-AC-TECH liked this post.
  7. #44
    Oct 2015
    Chino, Ca.
    So, I dug a little deeper and found out that the factory setting was set to 67% indoor fan. I adjusted it to 100% and the capillaries and bottom of the indoor coil stopped frosting up and the pressures adjusted up to about 104 and 310. It was about 70 indoor and 70-75 outdoor.
    I think the low fan speed was the issue! What are your thoughts?
  8. #45
    Jul 2011
    DFW, TX.
    Check the motor shive you probably can adjust it to speed the blower wheel up. Fact is you really should check the static pressure as that is a tell all.
  9. #46
    Jul 2011
    DFW, TX.
    What are they expecting space temp wise from this unit? They wont get much bellow 70 given your suction readings...
  10. #47
    May 2018
    VA/DC
    very possible. did you check the other items at all. I'm just curious
