Results 27 to 39 of 47
  1. #27
    Jul 2011
    DFW, TX.
    Quote Originally Posted by HE>I View Post
    Yes sir I crawled in there and sealed everything perfectly!
    Ok good. Did the pressures change at all after? Given the time of year I'd say the return leak was your issue. With the low alarm. What was the sh and sc? Btw hows that pro membership going. You'll get more responses in a locked area of the forum. Maybe ask the mods to hook you up. Idk.
    Sent from my LG-G710 using Tapatalk
  2. #28
    May 2018
    VA/DC
    You should also take a look at the txv bulbs. Back in the day sporlan had it in the documents, now they don't. But the cap tube coming off the sensing bulb must be at the highest point. If it isnt the txv gets lazy so to say and it will create low pressure situations. Had a 48a that froze up on day one. Set the txv bulbs in the correct position and issue solved.
  3. Likes CEAS-AC-TECH liked this post
  4. #29
    Oct 2015
    Chino, Ca.
    Quote Originally Posted by Cool breeze 38 View Post
    This is good advice! I will take a look.
  5. #30
    Oct 2015
    Chino, Ca.
    Quote Originally Posted by CEAS-AC-TECH View Post
    They adjusted slightly. I just got a call from the customer saying its doing it again Any ideas?
    Also, still no response. I will submit again
  6. #31
    Oct 2015
    Chino, Ca.
    Quote Originally Posted by buford View Post
    Was it air balanced or proof of correct amount of airflow.
    No sir, it was not air balanced.
  7. #32
    Jul 2011
    DFW, TX.
    You gotta run through the settings and set it up.without that you'll be chasing ghost.
  8. #33
    Oct 2015
    Chino, Ca.
    Would you mind if I private messaged or texted you? The tech support isn’t helping at all.
  9. #34
    Jul 2011
    DFW, TX.
    Freezin while trying to get off tgis roof atm
  10. #35
    Oct 2015
    Chino, Ca.
    Yikes! God speed haha
  11. #36
    Jul 2011
    DFW, TX.
    Thanks. Its an od reznor that wont initiate heat sequence. Got two of these...
  12. #37
    May 2018
    VA/DC
    another thing with ALL rtu units. the factory sized pulley is set for a free flowing concentric ( no static) once you put it on a system with duct work the cfm drops due to static. On every 48 series unit i have put on a 1 inch bigger blower pulley. this about maxed out the amp draw and got the air flow up.
    I installed 3 48A 30 ton units. Before I changed the pulley I had horrible static ( vav system) and I maintained a 52 deg discharge at 100% fan with just two of the 4 compressors. Yeah thats no good. Changed the pulley and much better performance.
    An air balance is always best to make sure youre at the max cfm needed. Also do the math to check max blower wheel rpm.
  13. Likes CEAS-AC-TECH liked this post
  14. #38
    Oct 2015
    Chino, Ca.
    Say a prayer for that old feller and keep it moving haha my first reznor I spent a couple hours chasing a ghost
  15. #39
    Oct 2015
    Chino, Ca.
    Morning! Headed to the job now. Any advice for the start up sequence?
