Results 1 to 13 of 22
    Oct 2011
    Gladstone, Oregon (Portland)
    12" trunkline on 2.5 ton AC...lol.
    I dont usually do new construction but I am going out to help on a rough-in on Saturday to help catch us up. I was looking at the equipment and the associated trunkline sold. 12" main supply trunk and 2.5 ton equipment...lol.
    May 2014
    Bay Area California
    That's not out of the question, provided the trunk isn't wire flex, and the unit is spec'd for higher statics.
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Oct 2011
    Quote Originally Posted by BBeerme View Post
    Dont have the prints in front of me but I think it is about 20' of 12 then 90s and reduces down to 10 and goes another 15-20'.
    I dont know man....doesnt look right to me. And this isnt high static equipment. Standard .5
    Athens, Ohio
    Quote Originally Posted by Adlerberts-Protege View Post
    So it is the duct system we find in 90% of the houses.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Oct 2011
    It is, but we actually have a quality guarantee that the system will be designed within system specs, including proper static. This one worries me.
    Jul 2009
    South Carolina
    There is a common misconception about how much airflow can be achieved under static pressure because TEL of 100 ft. of duct is assumed. 25ft. of a 12" supply can easily handle 1000 CFM's at .1 static but the velocity will be high. It all depends on the rest of the duct system. Manual D compensates for the whole duct system by using the TEL of the longest run & uses the standard of static per 100 ft. of duct. It's an excellent system but it is not perfect.
    I worked some of those numbers out on this ductulator: https://oceanhvac.com/ductulator/
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
  7. Likes CEAS-AC-TECH liked this post
  8. #7
    Oct 2011
    Quote Originally Posted by garyed View Post
    Ya, I used to teach Manual D to a lot of companies when I was in Seattle. I know that our salesman are using Wrightsoft, and that they are supposed to be using it. Highly doubtful on this one.
  9. #8
    Dec 2012
    columbus, OH
    Thats pretty typical on a mobile come. Static pressure will be high no doubt.
  10. #9
    20' of 12" with 2-90s. When you include the transition to round at the plenum. Will most likely be close to 100' of TEL.
  11. #10
    Oct 2011
    No way is it going to push 1000 cfm.
  12. #11
    Dec 2012
    columbus, OH
    Why not?
  13. #12
    Mar 2015
    Tx
    Quote Originally Posted by Core_d View Post
    Why not?
    Put enough blower in it will
    I don't have a ducalator but IIRC 12" @ .06 or .08 is 700 cfm . It's too darned small unless it's a MH with hi static blower. Run a 10 to a couple of close boots will help
  14. #13
    Dec 2012
    columbus, OH
    Quote Originally Posted by oldguy1949 View Post
    Any constant torque motor will put out its design cfm at .9 static or higher with one of the upper speed taps used. Even a psc motor with most systems should do good enough. It happens everyday.
