Results 1 to 6 of 6
    Feb 2014
    How to find a packaged unit to house rain shield/shroud installer
    Hi. I'm in the Chattanooga area (in case someone needs to ask) and have installed a packaged unit. The old rain shroud was junk and I disposed, and I'd prefer to just hire this out, or if if there's an online service I can order the custom piece I can do that.
    Can someone either recommend what I would search for for that kind of work, or is there a place to order this kind of thing? Given the custom nature of this kind of work I imagine it'd be best to have a professional, but not sure where to start. The obvious answer is probably any HVAC contractor, but the few I've called they're only interested in whole installs or problem diagnosis.
    I can build it with marine grade plywood, but would rather have galvanized sheetmetal.
    Thanks in advance.
    Jan 2010
    Sea to Sky
    You need an HVAC duct company..then can fabricate something out of sheet metal
    Sent from my SM-G965W using Tapatalk
    Mar 2018
    Chico, Ca #StateofJefferson
    Is this just an open sided shed over the unit? I would imagine any sheetmetal company could fabricate it for you. Just remember most units require a MINIMUM 5' of overhead clearance to prevent air recirculation. I'd recommend more, dont like doing minimums. Why a rain shield though, these are designed to be exposed to the weather?
    Feb 2014
    Quote Originally Posted by Makeitcold View Post
    No, this is the outside transition shroud that goes over the supply and return that connect the outside packaged unit to the base of the house. Thanks.
    Emerald Coast
    You want a doghouse....
    Make a pattern and find a metal shop.
    Do not attempt vast projects with
    half vast experience and ideas.
    Mar 2018
    Recommend having your static pressure measured and any duct sizing changes done first, most equipment is oversized for the home with ducting to small for the unit. Old equipment could usually handle the abuse but new equipment needs to breathe
Tags for this Thread
