Results 1 to 7 of 7
    Oct 2019
    Highlands Ranch, CO
    Transformer voltage
    If a 240VAC to 24VAC transformer is hooked up to a 208VAC electrical system, can I expect to see approximately a 10% reduction in output power as it is receiving approximately 10% less input voltage?
    Jun 2006
    Yes
    Jun 2006
    It's a 10 to 1 transformer so you can expect the output to be 20.8 volts
    Cincinnati, Oh
    Quote Originally Posted by Myhvacguy1 View Post
    This is why most 240 volt transformers have a tap for 208.
    "Just get it done son."
    Dad adjusted
    Oct 2019
    Highlands Ranch, CO
    Thanks guys. You are always a great help
    Sep 2010
    MO
    To add to transformers in a question.
    How often have you seen ungrounded transformers? Its been hit or miss a handful of times. Specificly when u need to hold a leg on common to follow the voltage to be clear.
    If so have you added a ground to one before i havent tried?
    Any thoughts?
    Jun 2000
    WYO
    Many older furnaces, usually the pilot type, are set up that way. I do not ground them, leave them original.
