Results 1 to 13 of 17
    Oct 2011
    Gladstone, Oregon (Portland)
    Refrigerant tank blankets?
    This will be my first winter on the cold side of the mountains here in Oregon, have a quick question.
    We had our weekly meeting this morning and it made me think about tank blankets/heaters. How effective are they and who here uses them religiously in the winter?
    Jan 2010
    Unless you do refrigeration why would you be changing in the winter for a/c ? Even a heat pump it's not recommend.
    Southold, NY
    They have a place. Dont think Ive used mine in years!
    I dont even know where it is.
    Jan 2010
    They have a place. Don’t think I’ve used mine in years!
    I don’t even know where it is.
    I know where mine is, still in the wrapper it came in.
    Mar 2015
    Medford, N.Y.
    When necessary, I put the drum inside of the bldg or inside a warm water bath or in the cab of the truck while blasting the heat.
    Southold, NY
    Is that where I left it.
    Send it back, Ill send you a 6-pack!
    May 2014
    Bay Area California
    I thought that's what a torch or heat gun was for.
    I do a triple evac with nitro to remove non condensables.
    Jun 2017
    Portland, OR(Previous: Arizona, Texas, Oklahoma)
    I just moved back to Oregon from Phoenix AZ. I feel like i haven't been able to feel my toes in three weeks
    At least I haven't had to replace a compressor since I've been back (knock on wood)
    Sent from my LM-G710VM using Tapatalk
    May 2017
    richmond virginia
    Quote Originally Posted by FreeThrowGuy View Post
    Heat gun blasting that sucker. What im NOT looking forward to is RECOVERING charge on a roof in the cold. Now that sucks
    Jul 2018
    Wisconsin
    Quote Originally Posted by BBeerme View Post
    Exactly my thought. MAPP gas torch keep it moving.
  11. Likes icy78 liked this post.
  12. #11
    Oct 2009
    new jersey
    I use my map gas.
  13. #12
    New Brunswick, Canada
    I used the yellow Jacket Jacket one for a while, until the elements failed. I never bothered to replace it, as the cost was a bit pricey. It served it's purpose.
    Passenger cab with heat on, sink with hot water, torch, heat gun all depends on the situation.
  14. #13
    Lots of heat pump compressors re changed out in the winter. And you have to recharge the system.
    Then there are the commercial and industrial applications that use A/C 365.
