Results 1 to 13 of 14
    Nov 2019
    Winterizing 96% condensate furnace
    Hi, Just installed a 40K condensate furnace. This is a remodel and it's going to be a while before it is insulated. They want to be able to shut down the furnace for periods of time with the temperatures falling below freezing inside where the furnace is. I sloped the furnace toward the internal trap. I am thinking that they can use a shop vac and suck out the water from the trap. I am wondering if they need to worry about the secondary heat exchanger?? If so, I have heard that pouring the antifreeze used for motor homes can be poured through one of the unused ports of the exchanger until it fills the trap, leaving antifreeze in the exchanger. Any experience with this would be appreciated.
    Apr 2003
    Maple Grove, MN
    The shop vac sounds like a good plan. It should be able to suck out enough of the water out so that it wouldn't be a problem.
    If at First You Don't Succeed, Skydiving Is Not for You.
    Jul 2018
    Wisconsin
    The installation manual will show where to pour the anti freeze. Fill till it flows from the trap. Propylene Glycol/Antifreeze should be used. RV antifreeze/Swimming pool antifreeze.
    Southold, NY
    Once the insulation is in do you plan on using it?
    DO NOT run that furnace during any type of construction!
    Nov 2019
    Quote Originally Posted by Spitz View Post
    I read the manual and it does not have any instruction on winterizing. Have you done this procedure with the antifreeze?
    Nov 2019
    Jul 2018
    Wisconsin
    Carrier spells it out in there manual. I have personally never done it before.
    Jul 2018
    Wisconsin
    Southold, NY
    Can you answer this?
    Nov 2019
    It will probably be used during electrical and plumbing and sheetrock finishing.
    Southold, NY
    Quote Originally Posted by Jerimiah View Post
    Besides voiding the warranty it will kill that unit.
    That is not a construction heater, it can’t handle the dust.
    Rent a construction hearer(s)
    Apr 2004
    MN
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Jun 2012
    Northern NV
    When I was doing new construction, I made the contractor read and sign a disclaimer that the warranty was void if used during construction....
    Then offered one of my recycled electric furnaces to use for construction heat. Kept about 5 or 6 of them in rotation for this purpose.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
