Results 1 to 8 of 8
    Nov 2019
    York Chiller Flow Switch
    Good day guys. I am having issues with my water flow switch, the problem is I cannot find a replacement part since there is no item number visible and the york manual does not have the swtich as parts number. If any can recognize the type, model or a possible seller please let me know.
    Click image for larger version.
ID:	812577Click image for larger version.
ID:	812578Click image for larger version.
ID:	812579Click image for larger version.
    May 2012
    California
    It is a dp switch. I would replace it with a IFM. If you want to stay with dp switch you can get those any number of places
    Nov 2019
    Tank you for the info
    Quote Originally Posted by JEF1980 View Post
    Thank you very much
    Nov 2019
    Can someone recommend one? I just cant seem to find any on ebay.
    Jun 2008
    Windsor, Ont.
    http://www.pretempco.com/html/products.html
    These are what York uses from factory. Just have to know what DP is supposed to be. I usually install 20 or 40 paid as replacements.
    Nov 2011
    East Side
    JCI/york manufactures very few parts. They assemble parts from third party vendors into a component where they attach their part numbers for resale.
    Dec 2018
    I would upgrade to an IFM flow sensor. Im not a fan of DP switches. Too many issues (relays corrode, multiple leak points, pipe clogs, etc). Look into the IFM flow sensor kit.
    Somewhere in the world.
    I also agree with the IFM sensors as a replacement different options to choose from just remember these are wet sensors.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
Tags for this Thread
