Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 42
  1. #27
    Jul 2011
    DFW, TX.
    Quote Originally Posted by ARIOSTO1 View Post
    Yes the motor wires L1 and L2 when looking for continuity to equipment ground
    They beep that shouldn’t happen
    Why are you asking for help when you have a motor that is "short to ground". I say apply for pro membership one day, then utilize this site for the knowledge and experience. Long roaf ahead man...
    Sent from my LG-G710 using Tapatalk
  2. #28
    Southold, NY
    With both wires disconnected from everything your getting continuity to ground?
  3. #29
    Oct 2009
    Atlanta,Ga.
    Change the motor!!!
  4. #30
    Southold, NY
    Quote Originally Posted by Gleng View Post
    Change the motor!!!
    My gut is telling me hes getting back feed thru the controls.
    How does a 220 volt motor operate if grounded without overamping, 1/2 speed, and just getting real hot?
  5. Likes CEAS-AC-TECH liked this post.
  6. #31
    Jul 2011
    DFW, TX.
    That's exactly why I suggested he apply for pro membership. Something ain't right
  7. #32
    Jun 2013
    If l touch any of the motor lines either L1 or L2 to 120v the motor runs
    l mean with just one leg
    So I want to be sure thats not back feeding somehow
  8. #33
    Jun 2013
    Any ideas l don’t want to change that motor by mistake!
    This is tricky!
  9. #34
    Jul 2011
    DFW, TX.
    This has gone beyond open forum rules...
    Turn off the power, disconnect the motor. Ohm the windings between and to ground. What are your readings?
  10. #35
    Jul 2011
    DFW, TX.
    Its not tricky you just need more experience.
  11. #36
    Southold, NY
    I hope you’re playing with those wires with leather gloves on.
    The only time you check voltage to ground is to make sure there’s NO voltage present. After confirming there’s a good ground.
    To check components disconnect from the power source, ohm across then each leg to ground.
  12. #37
    Jun 2013
    Changed inducer problem solved
    And yes both leg on the inducer were grounded
  13. Likes CEAS-AC-TECH liked this post.
  14. #38
    Southold, NY
    Then it wouldn’t run full speed, over amp and burn up.
    Look up “Fasco Motor Facts”
    Read it!
  15. #39
    edmonds wa
    Sounds like Tranes inducers that ran like that, on the older Voyagers.
    UA Local 32 retired as of Jan 2020
