Results 14 to 26 of 42
    Oct 2009
    Atlanta,Ga.
    If you have a reading from windings to ground, the breaker should be tripping!!!!I never have seen a gas furnace with 240volts either.Should be 120volts.Is the breaker tripping? If you unplug the wires for the induced draft motor from the board, then give a call for heat,do you get 120 volts to the motor.If you turn the heat off, does 120 to the motor drop out?
    Jun 2013
    Well this is a gas pack, thats why is a fasco 208 240 inducer motor
    M n 712112033
    Now like when u have a one pole contactor
    One leg is life always
    In this case one leg is hot on that board
    The second one goes thru the relay
    For instance l seen grounded condenser and the condenser fan motor runs nonstop on 120 because there’s a circuit to ground
    That won’t trip the breaker
    Jun 2013
    Grounded don’t mean shorted
    Jan 2010
    You can have a winding to winding short and that might hold true.
    You said you had a short to ground and that will trip a breaker.
    Unless your equipment is not properly grounded.
  5. Likes CEAS-AC-TECH liked this post.
  6. #18
    Jun 2013
    This is not a short from winding to winding that will trip the trip the breaker
    But if a winding is going’s to ground it will energize and turn the motor
    There’s a electrical flow thru that winding
  7. #19
    Jul 2011
    DFW, TX.
    Answer this. Was the motor running non stop before you touched the unit? I assume not because you changed the ps. You have other issues other then the motor I bet. Like maybe the board something isnt closed when it is.
    Sent from my LG-G710 using Tapatalk
  8. #20
    Oct 2009
    Atlanta,Ga.
    Ok,never said it was a gas pack!!!Sounded like a residential furnace!!!Now it makes more sense.Got it!!! Still may have board issue, but Im not there.
  9. #21
    Jun 2013
    I found the motor running but the ps wasn’t closing so l replaced and the furnace fired up
    Then l found the inducer running non stop
  10. #22
    Jul 2011
    DFW, TX.
    If your motor is has a short ohm reading will show the short. Ohm it outand go from there.
  11. #23
    Oct 2009
    Atlanta,Ga.
    If you have one wire hot all the time ,the motor doesn't run until the board relay closes.It then gets 208/230 volts and runs.If the motor is shorted, it would be getting 120 volts.1 hot to ground.Then,the motor should be running half speed.It is only getting 120 volts now.So,is the motor running slower, with no call for heat.I would check the voltage to the motor when there is a call for heat(should be 230).with no call for heat(is it 120 volts)and running slower.Then maybe you are getting a reading to ground,keeping the motor running.But I think the motor would be running slower.
  12. #24
    Jun 2013
    Yes thats right, but it runs fast enough to pull the ps on 120v
  13. #25
    Cincinnati, Oh
    In 2 pages, I've yet to see a single reading taken that was valid to the diagnostic.
    Maybe your test on the windings, but I'm having trouble on understanding what you actually checked.
    It's time to get someone out there to help you, or call tech support.
    "Just get it done son."
    Dad adjusted
  14. Likes CEAS-AC-TECH liked this post.
  15. #26
    Jun 2013
    Yes the motor wires L1 and L2 when looking for continuity to equipment ground
    They beep that shouldn’t happen
