Page 6 of 14 FirstFirst 12345678910111213 ... LastLast
Results 66 to 78 of 174
  1. #66
    Southeastern Pa
    Quote Originally Posted by R600a View Post
    Last i checked the IAQ is still honeywell. At least the tech support for the IAQ is Honeywell.
    Sent in a state of increasing entropy using Tapatalk
    EVERYTHING says "Honeywell."
    The IAQ is on the Resideo stat page at the very bottom. All of the redlink and prestige line and all of the accessories are there as well.
    Honeywell does not appear in the URL for that page. It starts, "customer.resideo....."
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #67
    Jul 2019
    Oklahoma home its in the name
    Oh darn. Looks like they got their grimy hands in all of it.
    Quote Originally Posted by timebuilder View Post
  3. #68
    Atlanta GA area
    This includes even commercially used stats such as vision pro.
    OUCH...
    I have a bunch of Pro1's from a volume purchase (closed down supply house)...
    I use the T4 for basic stuff and the T6WiFi for high end stuff...
    For general stuff and rentals... the Pro1's.
    And for DF: I have some older Honeywell units with a module at the furnace.
    Sorry to hear of the problems with the T series stats...
    I DID have an issue with that cutsy little wiring gadget that snaps into the wall mount... seems one or more of the wires does not connect to the pin.
    Replace the wiring gadget, all was good.
    GA-HVAC-Tech
  4. #69
    Southeastern Pa
    That wiring gadget is apparently designed for use with 22 solid.
    Have fun trying to get stranded stat wire into it. I know I had fun.....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #70
    Jul 2019
    Twist neatly and pull out the soldering iron and some lead solder.
  6. #71
    Southeastern Pa
    No...we are not tinning wires out in the field for 60% of going rate.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  7. #72
    Aug 2018
    Piedmont Triad, NC
    I’ve never seen anyone pull stranded tstat wire. Was it commercial?
  8. #73
    Jul 2019
    I would. I always have an iron and a roll of solder handy. Not to mention like 8 sizes of heat shrink tube.
  9. #74
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Achso017 View Post
    Stranded is old school commercial.
  10. #75
    Oct 2013
    I did some additional looking around.
    If it is a thermostat, a combustion control, an electrical component, Etc....in other words, all of the Honeywell stuff you're going to find at the supply house.... it's now Resideo. It does not matter if the products are used in a commercial environment.
    Honeywell has completely separated from Resideo. They do not own it. They are due indemnity payments every year from both Resideo and Garrett, the turbine engine maker, which they have also spun off and is now a separate company.
    This means that Residio is 100% not Honeywell, and merely a user of their designs and service and trademarks which were a part of that segment of the previous Honeywell business.
    Nah, this isn't quite right. I was confused too and was doing research on it a while back. Honeywell definitely still kept the commercial stuff in-house. The easiest way to see how it got split up is to check out both the "customer" websites:
    https://customer.honeywell.com/en-US/Pages/default.aspx
    https://customer.resideo.com/en-US/Pages/default.aspx
    As you can see, the websites have the same design, but Resideo lists all the residential products and Honeywell lists the commercial products. There was some overlap in the lines, so you'll notice some identical products between the Honeywell and Resideo sites. I suspect that even though the companies are officially separate, the Honeywell and Resideo products are still being made in the same factory.
    I doubt the T6 issues are due to the split, since that stat was introduced before then. Still, given the overlap in products, it doesn't make sense to me why they did this spinoff. Again on the security side of things, you see the exact same products being sold under Resideo and Honeywell.
  11. #76
    Southeastern Pa
    Quote Originally Posted by ss120396 View Post
    The similarity is only temporary.
    The business news articles say that the only relationship left is the indemnity payments due to Honeywell from Resideo and Garrrett.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. #77
    Southeastern Pa
    Quote Originally Posted by 2sac View Post
    And long run cable for stats.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #78
    Southeastern Pa
    Not for these rates you wouldn't.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
