Page 4 of 19 FirstFirst 123456789101114 ... LastLast
Results 40 to 52 of 245
  1. #40
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by rglasgow View Post
    Took bad stats back to distributor today. They had heard about a recall from Honetwell but did not have any details.
    I work for a distributor and haven't heard a word. There was a recall on the vision pros. Nothing on the T6's as far as I know.
  2. #41
    Aug 2018
    Piedmont Triad, NC
    I’ve had a bad T6 out of the box within the last week. It wouldn’t close contacts from R to G on a call for heat (heat pump) or with the fan turned to “on”. Also, at a Bosch class yesterday the instructor told us not to use t6’s for a while as they used a slightly different relay in a current batch that was dropping voltage to the reversing valve.
  3. #42
    May 2018
    FLORIDA
    what's going on with this T6
    Visit our website at www.airconcomfortcooling.com
  4. #43
    May 2018
    Elizabethtown, PA
    Quote Originally Posted by 2sac View Post
    One of my distributor's technical support staff had been in contact with Honeywell regarding this issue on 10/8 per my sales rep.
    The distributor I talked with today had no knowledge of the issue. They want to swap out the T6 I got from them. I guess I'll have to show up with my tester.
    At this point, my date codes span 22 weeks. It must not be every T6 in that range or it would be a well known problem by now. I'm six for six since mid summer, though, so my luck is terrible. I think I'll be using T4's and T6WF's until I get confirmation that this is solved.
  5. #44
    Southeastern Pa
    Update:
    I went to the supply house this morning, and took one of the bad stats (1+1) in to the manager, and demonstrated the lack of contact closure.
    He said, go grab another one.
    Same thing.
    He grabbed a slightly different model (2+1) still a T6.
    Nada.
    He had me try the only 3 he had on the shelf.
    Nada.
    Nada.
    Nada.
    He says try a vision pro.
    I rigged up two wires to stick out through the hole with the stat snapped into the back, with the four AA batteries in place.
    Bingo.
    He let me keep the vision pro so I could finish the job that was on my schedule today.
    So...this is two branches of the same supply house chain, and ALL of the 1+1 T6 stats I bought or tried in the past 10 days are not able to send power out the W1 wire.
    I think there is going to be a big stink about this. I never had issues like this before Honeywell split off this business and let someone else use their name. The company making these stats is actually Resideo.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  6. #45
    May 2018
    Elizabethtown, PA
    The most recent info I got was that they do not have a serial number range of bad stats. I guess bad units were found outside of the initial range. They are saying that all "series 5" T6 thermostats are good. The bad ones I have are series 4. The series number is the sideways number between the sn and date code on the back.
  7. #46
    May 2018
    Elizabethtown, PA
    Quote Originally Posted by timebuilder View Post
    For 1H1C, you could go T4. They've been flawless for me.
  8. #47
    Southeastern Pa
    Quote Originally Posted by Rovert View Post
    I needed a wired remote.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. #48
    May 2018
    Elizabethtown, PA
    I see. I'm going to see if I can find some of the series 5's. This problem needs to get fixed sooner rather than later.
  10. #49
    May 2014
    Bay Area California
    Shares of Resideo Technologies (NYSE:REZI) fell more than 40% on Wednesday after the smart-home and security products company cut guidance, announced a management change, and said it was beginning a comprehensive operational and financial review. With the drop, the company's shares have now lost nearly 70% of their value since being spun out of Honeywell International last year.
    https://www.fool.com/investing/2019/...ashing-to.aspx
    Update:
    Same thing.
    Nada.
    Nada.
    Nada.
    Nada.
    Bingo.
    I do a triple evac with nitro to remove non condensables.
  11. #50
    Jan 2010
    Sea to Sky
    Lol....I'll bet Honeywell buys them back now....fixes things and sells them again.
    Sent from my SM-G965W using Tapatalk
  12. #51
    Southeastern Pa
    That is truly a stunning article.
    Clearly..... they need to get their house back in order.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #52
    Jan 2005
    Man wasn't expecting all these problems when I asked about them. I have had another fail since original post. Same failure on a Bosch inverter system. Randomly drops voltage to reversing valve.
