Page 2 of 19 FirstFirst 12345678912 ... LastLast
Results 14 to 26 of 245
    Jan 2005
    I will probably stay away from them for awhile then.
    May 2014
    Bay Area California
    I've installed more than I can remember in commercial applications. Had one fail a day or two later, fan wouldn't come on. Think I had another fail, but can't remember what or why. It's still my normal economical truck stock stat.
    I do a triple evac with nitro to remove non condensables.
    Jul 2019
    Oklahoma home its in the name
    Same here you get a bad one every once in a while of almost anything.
    Sent from my rotary telephone using Tapatalk
    May 2016
    Montreal,canada
    I had 2 fail on me within 6 months of installation: First one thermostat button were unresponsive to anything and after removing thermostat and battery for one week, put back the battery and seem to work but did replace since i dont trust it. Second one after big wind and lot of power surge thermostat lost ALL config and went back to default config.
    Apr 2006
    Houston, Texas
    Thanks for the info . We use them on all of our heat pump installs. Will keep a look out for problems, but, none so far
    Aug 2009
    Rhode Island
    we have also had to replace a fair amount of t6
    Jul 2019
    You know now that I think about it I think we've had problems on heat pump installs too but if I remember correctly the problem turned out that we were running all of the power through one safety and it just added up to too much amp draw all we had to do is switch the safeties to just shut off the condensing unit instead of the red wire to the thermostat and we never had the problem again. It may not be related to what you all have had but it does seem somewhat similar. Anymore if it's a T6 or T10 I wire the safety between the condensing unit and the thermostat because I don't want that little bit extra voltage drop before the thermostat. Seems to have taken care of the only problems I've had with the t series.
    Sent in a state of increasing entropy using Tapatalk
    May 2018
    FLORIDA
    never had problems with T6
    Visit our website at www.airconcomfortcooling.com
    Austin, Texas
    I am on jobsite now. Two furnaces not functioning. 27 volts R to C. 12 volts W to C. Jumper thermostat and both furnaces fire up.
    Southeastern Pa
    I installed four yesterday. I get a call today: three have failed.
    I go to the supply house down on Spring Garden st, and they have three available.
    None of them connected R to W1 when the display says "HEAT ON." I tested them right there at the counter.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2019
    I dont think that is a valid test unless you hooked it up to 24 volts but i could be wrong.
    Assuming that you are referring to the t4.
    Southeastern Pa
    Oh, its a valid test alright. The fourth stat that was heating the space passed it on the counter at the client's store.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2019
    Ok i must have been thinking wrong.
