Results 1 to 13 of 16
    Feb 2005
    Florida
    Manifold Gauges Are Obsolete
    Everything I work on now has transducers and thermistors. Why do I need gauges?
    montreal
    Gage are always accurate.
    More reliable than gimmicks.
    Don't need battery.
    And if you live up north display will freeze.
    Tool ain't making the technician.
    Just my feelings this morning.
    Nov 2011
    East Side
    Quote Originally Posted by jimp View Post
    how do you know if the transducers are accurate?
    How would you add refrigerant?
    "Right" is not the same as "Wise".
  5. Likes heatingman liked this post.
  6. #5
    Feb 2005
    Florida
    Quote Originally Posted by 71CHOPS View Post
    I have been using these (Carel) since 2002. What I have found is they're within 1% of my gauge set, and I have never had a bad one, only a bad cable or moisture in the plug. Bad cable or connection issue they read -623 in the controller.
    Totally trust them, because everytime I thought they were wrong, they were spot on.
  7. #6
    Nov 2011
    East Side
    I work on all different brands. I've found transducers from 3-50 psi off. Trust, but verify......
  8. #7
    Feb 2005
    Florida
    I never find that on the refrigerant side, but I do on the water side.
  9. #8
    Feb 2005
    Florida
    Southold, NY
    The problem with all this fancy electronics crap is when something fails, on a 3 day weekend, during harvest season. 70-Ton chiller is down, 1 million cases of wine are getting warm and I cant get parts!
  11. #10
    Mar 2015
    Medford, N.Y.
    I agree w/ that.
  12. #11
    Feb 2005
    Florida
    I don't have a problem with the advancement of technology. Its really great to have the advantages they give you.
  13. #12
    New Mexico
    Like electric test meters, digital or analog, there are times to have both.
    Give me a relay with big enough contacts, and I'll run the world!
    You can be anything you want......As long as you don't suck at it.
    If a person wants to create a machine that will be more likely to fail...Make it complicated.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
  14. #13
    Jul 2009
    Columbia, MD
    Ive replaced 15 or so carel transducers in the past 5 years.
    Everything is destined to fail at some point.
    I do agree, they are spot on when they work
