+ Reply to Thread
Results 1 to 20 of 26
Thread: Hard start and PTC soft start
    Jun 2018
    Bay saint louis ms
    I was wondering if soft start can be replaced with a hard start kit I think the name is PTC start assist on a Manitowoc I paid 80.00 dollars for this little capacitor and it’s getting hot or some reason checked amps perfect has any one tried to change this any thoughts or facts
    Jul 2010
    US of A
    Quote Originally Posted by Mars65 View Post
    It may be OK to use it temporarily until the proper part is installed. It is normal for them to heat up after first use. They work fine the first time then not as well after they are in the circuit. They will work OK again after the unit is off and it cools down again. They work better when there is a delay on make timer. Why was the original part replaced? That is pricey for that part. Not really the best choice for ice machines imo.
    Jun 2018
    Bay saint louis ms
    Quote Originally Posted by pageyjim View Post
    It may be OK to use it temporarily until the proper part is installed. It is normal for them to heat up after first use. They work fine the first time then not as well after they are in the circuit. They will work OK again after the unit is off and it cools down again. They work better when there is a delay on make timer. Why was the original part replaced? That is pricey for that part. Not really made for ice machines imo.
    It seems to be an original part I don’t think it was added
    Jul 2010
    US of A
    If it's an original replacement then it's fine and working normal. That would explain the price for it too I guess. It is probably just a PTCR. You can search for it here or google it for more info but it sounds normal for what you describe. I imagine it looks like a little keg right?
    Jun 2018
    Bay saint louis ms
    Yes sir you are right
    Southeastern Pa
    I would wean yourself away from using the terms "hard" and "soft." They don't really apply as you have used them.
    Typically, a "hard start kit" is for a compressor that is hard to start. It is not a reference to the start components.
    Both PTC and either potential or current relay setups are "start components," but the PTC is a cheap approach that has a VERY long cool down time after the initial use until it is able to assist in starting the compressor again. A potential relay works each and every time it is energized. Current relays have largely been replaced by the cheap PTC devices.
    The better idea is to say "start device," and specify the type being discussed.
    A "soft start" refers to a type of VFD drive that slowly begins to rotate a motor by ramping up to the prescribed operating speed.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  7. Likes icemeister liked this post.
  8. #7
    Jun 2018
    Bay saint louis ms
    They were called soft starts before vfds were invented
  9. #8
    Jul 2010
    US of A
    I think there is some confusion in the industry concerning start kits-devices. Just because a company labels something a "soft start" doesn't necessarily mean that it is one imo. I don't know if you have 20 years in or are somewhat experienced with fewer years in but many in the trade will judge you in how you phrase things. Just the way it is. I think you may find the link below somewhat informative. I don't think it addresses the vfd drives TB was rightly talking about.
    https://www.hvacrschool.com/this-is-not-a-soft-start/
  10. #9
    Oct 2011
    Chicagoland Area
    It's a ptcr and it's supposed to get hot. It's not a capacitor, it's a relay that drops out on resistance created by heat.
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  11. #10
    Jul 2010
    US of A
    I think he knows that from the first time it was stated.
  12. #11
    Oct 2011
    Chicagoland Area
    I posted before I had a complete thought
  13. #12
    Jan 2010
    I don't know about that, I read that as a question as to why it was getting hot.
  14. #13
    Jan 2010
    it’s getting hot for some reason checked amps perfect
    Here ^^^^^
    P.S. I add the presumably " f " to or .
  15. #14
    Southeastern Pa
    I think you can still view Payson's video on YouTube where he compares a ptcr type start component to an actual potential relay start component, and he shows how unreliable the ptcr is for attempting to provide assistance to start a compressor.
    Maybe...just maybe.... it is possible that some people have used the term "soft start" to describe a ptcr device, but over the past 20 years I have only seen "soft start" associated with a device which ramps up a blower motor from a dead stop to full speed to avoid the jarring loads and sounds produced by the sudden engagement of a high horsepower 3-phase blower motor.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  16. #15
    Jul 2010
    US of A
    Here ^^^^^
    That was already addressed also.
    " It is normal for them to heat up after first use. They work fine the first time then not as well after they are in the circuit. They will work OK again after the unit is off and it cools down again. They work better when there is a delay on make timer. "
  17. #16
    Jan 2010
    That's your quote not his. Let's assume he understands it.
    These work fine on ice machines I rarely have any issues with them.
    It's not like a a/c unit that can short cycle.
    Ice machine compressors come on and stay on until their bin is full.
  18. #17
    Oct 2011
    Chicagoland Area
    Carrier used them for a short stint on their units as well. They like to start on fire
  19. #18
    Jul 2010
    US of A
    They can't short cycle? That is like saying a comfort ac stays on until the thermostat is satisfied. Ice machines don't have pressure switches or get dirty coils etc?
  20. #19
    Jan 2010
    Yep, I've replaced them on Carrier's with hard start kits.
  21. #20
    Jan 2010
    No where close to comfort cooling. They slow down on production typically. Try shutting off a condenser fan motor on a a/c unit and see what you get. Ice machines do it every harvest.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
