Page 1 of 4 1234 LastLast
Results 1 to 13 of 51
    Caledonia WI
    Hack waterheater vent.
    Man-o-man...
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
    Mar 2016
    Dayton Oh
    Should naturally draft just fine.
    Aug 2015
    Buffalo,NY
    I’ll take low boy hot water tank for $300 please
    Jan 2012
    Broomall, PA
    I guess your talking about the immediate 90° elbow
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Aug 2015
    Buffalo,NY
    It Ohmost looks like the backdraft diverter was cut down also. Might just be the angel.
    May 2014
    Bay Area California
    Does that vent dump into a return duct?
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
  7. Likes Core_d liked this post
  8. #7
    Caledonia WI
    Yes, they cut it way down. It's not going to help at all if there's a down draft.
    Quote Originally Posted by Metalman0880 View Post
  9. #8
    I don't see the problem. What is it?
    PHM
    Quote Originally Posted by billg View Post
    Man-o-man...
    PHM
  10. #9
    Caledonia WI
    Draft diverters aren't very good anyway, better to have a barometric draft control, what they did is cut the legs mostly off of this one making it even worse.
    Quote Originally Posted by Poodle Head Mikey View Post
    PHM
  11. #10
    Nov 2011
    East Side
    I was at a buddy's house one time. they were asking me about running gas line or something, and casually mentioned that when it's real windy outside, sometimes they have to relight the pilot on the water heater. I found all the legs bent out on the draft deverter and the cone flat against the top of the heater. Got a good chuckle out of that one.....they seemed to think it was a normal thing. they'd been in the house several years! LOL!
  12. #11
    Jan 2010
    Well we all know the tab typically goes into the slot on those.
    It appears they just bent one leg to hold it in place.
  13. #12
    Nov 2014
    Northern Idaho
    Are you going to repair it? Looks like you don’t have room for a barometric
  14. #13
    Feb 2011
    Chicagoland
    A 4" bull-dogged tee with a barometric damper would fit. The curled plastic on the top of the heater is a sure back-draft sign.
    After you learn refrigeration, fixing an A/C is like a walk in a park under shade trees
