    Oct 2019
    Ductwork sizing.
    I have a Goodman heat pump GPH1448M41AB (nominal cooling cfm 1600) installed and I am running all new ductwork under a mobile home. The return air is 16" and runs approx 36'. The supply side has not been run yet, but it will be approx 2 runs of 50' with a branch joining the two runs. I have 9-4x8 vents which can be enlarged. My question is, What is the smallest supply duct I can run? I was going to run 14" but limited headroom wont allow that past the first 30'. I have no idea what I am doing, I need to get it as close to right the first time. Thank you for your advice. I'm just a homeowner trying to get by.
    Jan 2012
    Missouri, USA
    You may not have noticed the big red letters that read NO DIY. This site is not for diy. Good luck.
    Southold, NY
    You need a Manual D run!
    Feb 2014
    Phoenix Arizona
    There always seems to be enough money to have it done right the second time...
    Sorry, this is not a DIY site.
    Thread closed.
