    Cleaning vs replacing bypass humidifier pad
    What are the risks associated with cleaning and reusing a bypass humidifier pad? I have an Aprilaire setup and my house is on soft water. The pad gets quite a bit of salt deposits on it but when you run it under water, it cleans right up and looks just like a brand new one out of the box. I am sure there is a reason to not just clean it and reuse it but I can't find any information on the topic.
    What am I missing?
    Thanks.
    Jan 2012
    Missouri, USA
    Cleaning is fine, I use vinegar on mine at home.
    Athens, Ohio
    A clean pad is all that is needed. Soft water does not cause the pad to deteriorate. Hard water eats up the pad in a year.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Thanks for the replies everyone. I'll clean it thoroughly and reuse.
