Results 1 to 8 of 8
Thread: Ac freezing
    Oct 2019
    Ac freezing
    Blower motor went out a/c repairman replaced the motor and everything worked great then after a month we started hearing a loud noise from the inside unit well the blowers fan blades had some how came apart at the weld and still was spinning and blowing hard cold air through the vents but it was jumping and making a horrible noise so repairman came out replaced the Blowers fan blade put the new motor back on the blower then put the squirrel cage and all back in the unit wired everything up and turned it on it works but its not blowing as hard as it was and now the inside unit after about 45 minutes freezes up and before the fan blades broke you could feel the air being pulled into the coils to the blower but now it feels like its barely sucking any air into the coils to blow out the vents. Just asking what might be causing it to freeze and not blowing as hard as it was before
    Jun 2014
    Dover, DE
    May be the wrong wheel, or installed backwards.
    Either way you’ll want to get it addressed quickly.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Southold, NY
    Quote Originally Posted by Steve2990 View Post
    Resend with proper pronunciations!
    Oct 2014
    Saint Pail, Minnesota
    There’s a period in there.
    Nov 2011
    St. Louis
    ^ This is just rich.
    (punctuation)
    I never hear any pronunciations here...ever.
    Is the Religious Right to blame for Christianity's decline?
    They argued that, as the Religious Right became increasingly visible and militant, it became associated with Christianity itself. And if being a Christian meant being associated with the likes of Jerry Falwell, many people—especially political moderates and liberals—decided to simply stop identifying as Christians altogether.
    http://www.theamericanconservative.c...nitys-decline/
    Just based on your statements I would want to make sure that the correct blower wheel was installed, properly, and that it is turning in the correct rotation.
    PHM
    PHM
    Quote Originally Posted by Pnasty View Post
    Yes there is.
    Phoenix,AZ
    When's the last time you replaced your filter or did you switch to filtrete right before the repairman arrived?
