Results 1 to 12 of 12
    Sep 2019
    Exposed thermostat wire splice at condenser ok?
    Hello,
    I recently had my ACs replaced and it looks like they spliced the thermostat wires outside that go to the condensor because they change the position and needed extra length.
    What I noticed is that the splices are exposed to the elements instead of wrapped or being sealed in some way. This doesn't seem correct to me.
    Please advise.
    Thanks!
Size:  55.9 KBName:  20191026_123540.jpg
    Southold, NY
    There are other ways to do that.
    Wire nuts are hats not cups!
    Oct 2016
    Clearwater, Florida
    Unprofessional.
    I would have at least electrical taped it but pointed the wire nut up to keep rain from getting in it.
    Just common courtesy.
    Oct 2011
    Gladstone, Oregon (Portland)
    Ya. Too much room for something to go wrong there.
    Jan 2014
    New England
    Is it registered, ( indoor/outdoor section ) warranty decreases significantly if never registered.
    Sep 2019
    Thanks. Yes I did register the equipment for the warranty.
    What would be the best remedy for this?
    Southold, NY
    Splice the wire inside the house and run a new one!
    Jan 2014
    New England
    Quote Originally Posted by Barelyhandy81 View Post
    Best remedy, IMO run the stat wire in a dedicated sealtite/liquidtite 1/2” and fittings on each ends.
    Southold, NY
    Quote Originally Posted by Bazooka Joey View Post
    In Sealtight!
    Best would be an entire new control wire run from end-to-end.
    But a fully acceptable remedy would be a water tight electrical box mounted to the outside of the foundation wall with the connection made inside the box. Preferably with both wires entering the bottom of the box.
    A lesser but adequate remedy would be to make the connection as pictured but with the wire nuts filled with No-Ox paste before screwing them on and then secured with the open ends of the wire nuts down.
    PHM
    PHM
    Jan 2014
    New England
    In Sealtight!
    Ya, Ya,...that stuff..
    VA
    Tape it with rubber or electrical tape. Connecting the wires outside the cabinet may be required on some equipment, as the low voltage wiring is class 2, and cannot be located within the same compartment as class 1 without a shield to separate them. Some manufacturers install this shield, and some don't. Not really a big deal.
    The wire connections below the refrigerant tubing should be wrapped with tape. Rubber tape usually works pretty well.
    I don't really think seal tight is a good option because you leave the ends opened which allows water or condensation to occur. This in turn will cause your wires to take much longer to dry. You could seal the ends, but is all that really necessary? Just use some rubber tape and be done with it.
    "The only true wisdom is in knowing you know nothing" Socrates
