Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 53
  1. #40
    Southold, NY
    The only metal panel I can think of is the plate that forces the air out. We remove it to change the blower wheel, maybe some fool forgot to put it back!
  2. #41
    Southeastern Pa
    So much left to wonder about.....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  3. #42
    Jul 2011
    DFW, TX.
    I be its the panel carrier uses to cover the blower. The one with the control board mounted on it that must be removed to access the blower.
    Sent from my LG-G710 using Tapatalk
  4. #43
    Southeastern Pa
    Quote Originally Posted by bulldog53038 View Post
    TRANE XE1200 1.5 TON MODEL#TTPO18C100A2 .
    I don't think Trane will use a Carrier part.....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #44
    Jul 2011
    DFW, TX.
    Ah... Smh
  6. #45
    Mar 2016
    NY
    The suspense is killing me. Op tell us what the plate was
  7. #46
    Southeastern Pa
    How about...some pictures??
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. Likes Achso017, CEAS-AC-TECH liked this post.
  9. #47
    Aug 2009
    Beatrice, NE
    He said the inside unit was a TWH. That is a horizontal unit, coil on one end, blower in the middle, with a place for elements on the outlet end, the blower attached to this box for the elements. It seems like those came with an opening for the elements and if no elements were used you had to put a plate over the opening otherwise the outlet air off the blower would blow back to the inlet side of the blower. That hole was about 5x12 so you could get a fair amount of air through it.
  10. #48
    May 2014
    Bay Area California
    That's called the blower cut-off plate.
    It can vary dramatically depending on the use of the blower. Meaning, low pressure high volume Vs high pressure low volume.
    I do a triple evac with nitro to remove non condensables.
  11. #49
    Nov 2019
    Hi everyone,
    First post on here. I'm a maintenance technician in florida and have been doing it for about a year.
    I had a similar issue on a carrier unit where the heat strips/kit had been removed or never installed. There was no plate or anything like that, just a gaping hole above the blower. i thought that was pretty wierd.
    I dont remember the pressures or anything like that.
    I called my field supervisor and asked him if that was ok to be like that and he told me it was fine. Is it okay to leave it like that?
    thanks and glad to be a part of the forum!
  12. #50
    May 2014
    Bay Area California
    On some units, the exterior panel would probably make the 'seal'. Doubt I would leave it that way though.
    Quote Originally Posted by mattschrader View Post
    Hi everyone,
  13. #51
    Nov 2019
    BBeerme,
    Yeah I felt the same way. I hate to leave things halfway like that but I gotta do what my supe says and there was no way I could have done anything about it. We didnt install it at least.
    Still bugs me though
  14. #52
    State College, PA
    Hi everyone,
    Welcome to the forum.
    I have seen quite a few like that. There was a time that Carrier/Bryant/Payne was shipping the air handlers out without that plate assuming that you would be putting in heat stips, even on straight a/c. I think that has changed now.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
