+ Reply to Thread
Page 6 of 28 FirstFirst 1234567891011121316 ... LastLast
Results 101 to 120 of 543
Thread: Any Chevy motor heads here? This one is kicking my butt -
  1. #101
    Jul 2010
    US of A
    Distributor caps contacts are silver-colored - not yellow-metal colored - so I'm voting for "aluminum".
    I will change the fuel filter.
    Getting the gas tank filled before the engine runs is likely more work that I'm up for. And heretofore the engine has freely started even when the fuel light has been on.
    Once I get the timing chain renewed and it all bolted back together under cover I'll see what the Snap-On live data scanner has to say.
    $9,000. for the SOB - so it Better know every Possible thing about the van! <g>
    PHM
    Good luck.
  2. #102
    Dec 2012
    columbus, OH
    9k? I would have tried another engine first....
  3. Likes BALloyd, Metalman0880 liked this post.
  4. #103
    Apr 2012
    PHM
    Lot of green PHM... With that kind of money to burn...I would toss a new distributor cap and rotor on it and see what happens.
    If you spend that 9 k it's gonna take a while to make your money back ..it would need to stay pretty busy .
    9 k will buy you another van as far as that goes
    Sent from LG Stylo 4 using Tapatalk
  5. #104
    Quote Originally Posted by Missouri Guy View Post
    Yeah, was thinking something similar...
    However I fully understand the:
    I AM gonna figure this out
    Attitude!
    Been there many a time!
    And from reading PHM's posts... he will make the $$$ back using that tool to barter favors from other folks.
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  6. #105
    Virginia
    Quote Originally Posted by Core_d View Post
    Im gonna guess after hes done with snappy , its going back up for sale for 9,000
  7. #106
    Southeastern Pa
    PHM...
    As soon and the chain and sprocket are in place, before you button it up, look in the hole while you crank it by hand......
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #107
    Southeastern Pa
    And...
    Quote Originally Posted by timebuilder View Post
    Refresh my memory, Mike.
    Did you have spark at the plug boots?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. #108
    Dec 2012
    columbus, OH
    Quote Originally Posted by Snapperhead View Post
    Prolly goes for 4.5 once the box is opened.
  10. #109
    Aug 2009
    Beatrice, NE
    PHM
    For $9K my son would have come down and diagnosed it for you. May have even fixed it for you for that price.
  11. #110
    Jul 2010
    US of A
    I know Forscan has a program for Ford products which is as good or almost as good as a dealer scanner for a low price or is possibly free. I know some versions are free. It works through the ELM327 modules. I wonder if there is an equivalent for GM
  12. #111
    Jan 2010
    Sea to Sky
    Unlikely....you should see the prices of ones that are several years old.
    Sent from my SM-G965W using Tapatalk
  13. #112
    Southeastern Pa
    When I was still in the shop, I think they went for at $2k for the basic package, and additional cartridges were additional cost.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  14. #113
    Virginia
    You talking about the snapon "brick " ?
    Mines sitting in the garage under tons of dust
  15. #114
    Dec 2012
    columbus, OH
    Harbor freight has a nice looking one for about 12 hundo. Says it compares to SO’s 35hundo scanner
  16. #115
    Dec 2012
    columbus, OH
    Correction 45hundo
  17. #116
    Bedford,Ohio
    Update?
  18. #117
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Well . . . . .
    I got the old sprockets off and the new ones partially on but was stopped by this oddity:
    The original chain tensioner looks like this:
    https://www.napaonline.com/en/p/NTP9...+tensioner+arm
    Of course; no one has it in stock.
    The "timing chain & sprocket kit" that everyone Does stock has a chain tensioner which looks like this in it:
    https://tinyurl.com/y4zze2r2
    Even if I try to buy the tensioner as an individual part - it looks like the elaborate one.
    And no one seems to know if the elaborate one is some kind of upgrade, universal-fit, or whatever. It comes with some pins for which my block does not seem to have holes. It actually looks to me as though it may interfere with the timing cover.
    NAPA says they are getting me one of the original version type.
    So I haven't been working on the truck.
    I'll see if I can get a picture onto this computer of what I Have been working on.
    Quote Originally Posted by 6t7gto View Post
    Update?
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  19. #118
    Jan 2010
    I thought you were/was working on a hardwood staircase ?
  20. #119
    There are a bunch of little eff-ups but eventually I figured: nobody sees that shet anyway. I started out to build it entirely of pine and stain it 'Gunstock'. So I cut off the bullnose and edge glued several pine treads into that large board for the bottom-step platform. But the available treads proven to such garbage that I switched to manufactured oak treads. Then I thought: I can more easily darken it later than I can lighten it later so I used 'natural' stain instead of 'gunstock'. The lighter stain hid fewer imperfections but eventually I said eff this: my truck doesn't run!
    My entire house here was originally paneled in 3/4" T&G 1 by 10's of aromatic cedar. That was what was removed from this area to build these stairs. The cedar had gotten to be about the color of light mahogany over the years.
    The primary problem was that the staircase-hole in the ceiling and the staircase-hole in the floor are skewed to each other. So every angle cut Also has to angle diagonally across it's face by a couple degrees. The railing ends and Every baluster is different and required a separate jig setup. Plus all the angles are greater than 45º so a standard miter saw would not cut them. Every riser and every tread was not even a parallelogram - often each of the four corners was a different angle.
    So no; I haven't gotten the truck back together yet. <g>
    PHM
  21. #120
    Jan 2010
    Looks good to me
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
