    Oct 2019
    Energy calculation for augmenting heat
    I have a 75 square foot Mudroom/Laundry room off my garage. It is cold. The space does not have a heat source and relies on air movement from adjoining space for heating. It is connected via a regular 30 inch door. In winter (zone 5) I use a table fan to blow air out of cool space into the warm space. It helps, but it is still a little cool.
    My question is around energy consumption for a small electric heater to augment the current situation
    Would the energy consumed be equal to the amount of btu required for the temperature differential? I.e. I could calculate BTU required to heat 75 sq feet from 60 to 70 (10F)? Online calculators indicate roughly 1500 btu, 450 watts.
    Is the calculation that simple, or does the in-room heat source somehow reduce the heat gained from the adjoining room such that the electric heater is providing more than the 10 degree differential?
    Southold, NY
    Mud room in a cold environment I would use in floor radiant
    Water or electric.
    Keep the floor warm, that’s all you need!
    Oct 2019
    Water or electric.
    Hmmm.... the hot water tank is in the same space. A mini hot water radiant setup is an intriguing idea.
    A little 500 to 750 watt electric baseboard should do fine for that area.
    Radiant floor is great, but might cost more upfront then it’s worth for a mud room/laundry room.
