Results 1 to 13 of 14
    State College, PA
    Anyone see this before?
    Have you ever see a king valve cap split like this?Name:  output.jpg
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
    Jul 2011
    DFW, TX.
    Looks like someone tried to seal a leak.
    Sent from my LG-G710 using Tapatalk
    Southold, NY
    Quote Originally Posted by joemach View Post
    Not on tight
    Moisture condensing / Freezing
    Get enough in there CRACK!
    Aug 2018
    Piedmont Triad, NC
    Nope
    Virginia
    That there - is one of those things we will never know the story
    yep don't know why but has always been a parker valve. freeze sounds legit, never thought of that!
    May 2018
    Elizabethtown, PA
    I've never seen it but my first thought was that there was water inside and it froze.
    Mar 2018
    Florida
    to me looks like someone did not see the service wrench insert was still in there and put thr cap on and tightened it down way to much and punched a hole thru the soft brass.
    Oct 2019
    No, haha, never saw that either. I'm going with water in the stem, (full to the brim) and then cap tightened. Then froze. In fact I'm going to do that intentionally on my personal condensing unit just to see if it happens It will freeze soon. I have to replace my unit next spring anyhow, dog peed all over the fins. Better sacrificing my unit for science than a customers
    Oct 2019
    I wish I had 5$ for every time I've said "I've never seen that before"
    Jan 2010
    Yep, seen that once. Was on a outdoor walk-in freezer condensing unit.
    Nov 2019
    Water freezing looks about right. The damage came from the inside so that's about the most logical thing I can think of.
    Jun 2006
    Pretty common on walk in freezers of the heat craft group, they use those same valves on the tin can and scroll condensing units.
    They usally just split on that outer seam, the star cracks in the middle are not as common. Soap bubbles or water in there will get it done quick at freezer temps. A -10 freezer is going to flirt with 0 degree return vapor temps and the frost, melt cycle will leave water inside a loose cap.
  14. Likes CEAS-AC-TECH liked this post
