Results 14 to 26 of 27
    Oct 2016
    I’ve heard it works fine. Agin the rules...but will work.
    Southold, NY
    Quote Originally Posted by Scoobie View Post
    It might WORK fine but then someone comes along and recovers that mess and get hit with a disposal fee because some a$$ wipe mixed refrigerants!
  3. Likes CEAS-AC-TECH liked this post.
  4. #16
    May 2003
    Utah
    Not only is it illegal, once you make your own personal blend...you now have no idea what the pressure-temperature relationship is.
    Which means, if your one of those technicians that is actually concerned about subcooling and superheat, it will be impossible to measure it.
  5. Likes CEAS-AC-TECH liked this post.
  6. #17
    Nov 2014
    Chicago Illinois
    ive found this summer that fluctuating pressures happen when combining the two together. When recovering then replacing its fine but a vacuum (full) is usually required to actually make it work the way its supposed too.
    We always recover then replace. saves problems it seems.
    Steve
    Faith Heating & Cooling Chicago
  7. #18
    Oct 2014
    Saint Pail, Minnesota
    Mixing is lazy, just like bypassing certain components.
  8. #19
    Sep 2016
    Pepe be careful, R407 is not miscible with mineral oil, therefore, if you have it ... no more lubrication after R22 disappears
  9. #20
    Jul 2011
    DFW, TX.
    Rs44b...
    Sent from my LG-G710 using Tapatalk
  10. #21
    May 2017
    richmond virginia
    Quote Originally Posted by Pepe The Frog View Post
    One of the fellas at the parts house was trying to convince me that 407C on top of R-22 was a good idea. We've been recovering all the 22, making necessary repairs and then replacing with 407. Has anyone heard of people putting 407 on top of 22? ...on that note I was getting some odd fluctuating pressure readings on a unit but the line temps remained the close to the same. Oh, and the system was cooling.... Anyone have any thoughts?
    I have definitely seen it done in the past but just like stated before it's illegal and although it will work it causes too many problems. If you watch your gauges after it's been added you will see a crazy fluctuation almost like a TXV hunting but way more erratic. It just simply should not be done
  11. #22
    May 2018
    FLORIDA
    Remove the 22
    do a new charge with 407 and put a sticker on the side of condenser saying R407C
    Visit our website at www.airconcomfortcooling.com
  12. #23
    Southold, NY
    Quote Originally Posted by AIRCON8 View Post
    Remove the 22
    Might want to put some POE oil in there...….at the least SUPCO 88!
  13. #24
    Oct 2019
    North Texas
    Remove the 22
    Yep. Of course. That's what me and my guys have been doing. I have since talked to the branch manager about the "information" his counter help is giving out...
  14. #25
    Oct 2007
    Broward County, FL.
    The counter guy was most likely repeating what he heard from some of the guys buying 407C, in his mind he may have thought that he was passing on useful info to other customers.
    We as contractors or techs need to filter out erroneous technical info we are given be it from a counterman, manufacturer, fellow tech or even boss. I would not have taken offense at the counterman being misinformed, I would have been more irked if he tried to convince me to use a leak sealer.
    I may have told him to be careful because what he was recommending was against the law and left it at that.
    I miss you mom and dad.
  15. #26
    May 2018
    FLORIDA
    Quote Originally Posted by SkullMonkey View Post
    The counter guy at Goodman today told me he don't know what NATE is. At the beginning i tough he was joking, then a couple of other guys join the conversation, he was not joking...Welcome to Florida. LOL
