Results 1 to 13 of 33
Thread: Cap question
    Oct 2007
    Austin Texas
    Cap question
    Has anybody piggybacked a low performing cap to increase its rating to get it by temporarily.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    Mar 2019
    No I’ve piggybacked caps to get the proper size when I didn’t have the right one . I have also added a slightly higher mfd rated cap on to get a customer by until I could get the right one . In theory , say that you needed a 40 mfd , the cap that was on the unit was reading 30 you could wire in a 10 to make it a 40 I don’t see how that would be any different.
  3. Likes CEAS-AC-TECH liked this post.
  4. #3
    Jul 2019
    Oklahoma home its in the name
    I usually just piggyback 2 new incorect size ones to get by temporarily. I it would probably work fine but i wouldn't do it.
    Sent from my rotary telephone using Tapatalk
  5. Likes CEAS-AC-TECH liked this post.
  6. #4
    Oct 2007
    Austin Texas
    I don't feel so bad then. I didn't have a forty on board their cap was 33 out of forty. I threw in a 7.5 until tomorrow. Just wondered if anyone else had to do this.
  7. #5
    Feb 2016
    Roanoke, VA
    Capacitors are cheap. Why wouldn't you just have two of each of the most popular caps (so you don't run out that day) or get a turbo200?
  8. #6
    Mar 2018
    Chico, Ca #StateofJefferson
    If the compressor wasn't running with the cap as is and I couldn't jump a couple new ones together to make 40, only then would I do that. The part is failing, it might not make it until tomorrow, but if it all you got it's all you've got!
  9. #7
    Apr 2006
    Houston, Texas
    Sometimes you gotta do what you gotta do to get someone by until you can do the right thing. It will work as long as the bad cap doesn't get worse.
  10. #8
    Jul 2011
    DFW, TX.
    Always check a cap under load. It'll give the most accurate reading.
    Sent from my LG-G710 using Tapatalk
  11. #9
    Southeastern Pa
    When I have had to parallel two capacitors to make up the proper rating, I start with two brand new caps.
    I would not trust a failing capacitor to maintain that 30 out of 40 microfarads..... even for a week.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. Likes CEAS-AC-TECH liked this post.
  13. #10
    Virginia
    When I add 2 together ... I never go back
    They actually last wayyyyy longer
    In fact I was cleaning a evaporator coil at this house and it occurred to me , hmm , isnt this one of my ghetto units ?
    Went over to OD unit , pulled the cover .... holy crap , piggy caps still there 8 years later still rockin it
  14. #11
    Southeastern Pa
    I have to maintain OEM approaches to the devices being used.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  15. #12
    Jul 2018
    I carry the right ones on my truck 2 to 80uF. But if you are going to piggy back two together, they should be close to the same rating-like two 20's or a 15&20 versus a 5&30. A good senior tech taught me that.
  16. #13
    Virginia
    Quote Originally Posted by george3 View Post
    Did he explain his reason for that?
    I can't think of any rational for it.
