Results 1 to 9 of 9
    Sep 2019
    Pevely MO
    Compressor check
    Question on compressor
    I was told by instructor that start-common ohms plus run-common ohms should equal start-run ohms. If you are off by .1 or .2 ohms, is that an indication of a probkem with compressor.
    Jul 2012
    WA
    No, .1 or .2 ohms is not a big deal.
    May 2017
    richmond virginia
    no youll find that to actually be the norm because .1 might be the true reading or it might be the tiny bit of room that all test instruments give themselves for flaws.
    also that trick only works with single phase. with 3 phase that wont work. the numbers will all be the same
    Southold, NY
    Quote Originally Posted by rb9594 View Post
    A compressor is just a motor so
    Start Reading
    Mar 2018
    Florida
    Thanks for some reading material. I just love how thru the whole article it keeps going...FACT.
    But all joking aside lots of FACTS in that pdf.
    May 2014
    Bay Area California
    Unless it is a Scott-Tee compressor.
    https://hvac-talk.com/vbb/showthread...iterature-typo
    Quote Originally Posted by kennybaker2014 View Post
    I do a triple evac with nitro to remove non condensables.
    Mar 2015
    Medford, N.Y.
    Is the comp overload internal to the comp body? Going S-R does not go thru the overload.
    May 2017
    richmond virginia
    Quote Originally Posted by BBeerme View Post
    Thats an itereating setup. Never seen one in person but i guess now i know that its out there. Thanks for pointing that out Bbeerme
    May 2014
    Bay Area California
    Yeah, it's a new one on me as well.
