    Oct 2019
    statesville , nc
    Emer heat problem
    Nordyne E2EB-015HB. Goodman HPT18-60w thermostat. Emer heat does not work - normal heat pump works fine. Red light on thermostat does not come on. Check heat coils with meter - they are OK. Can't find how to troubleshoot thermostat or what else to test. All help appreciated.
    Jun 2014
    Dover, DE
    What does your service technician suggest to fix the problem?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Local 486
    Southold, NY
    Call for service before it gets cold!
    SW FL
    Designer Dan
