Results 1 to 9 of 9
    May 2005
    Wrong parts installed @ the factory..warranty???
    On 6-29-18 I installed a new condensing unit..fast forward to 2 days ago, customer said it’s not running..found start capacitor blown..I called my supplier to get new components and there was a problem, the start capacitor I told them I had didnt match what they said it needed..
    So I called the manufacture, they said that my supplier was correct it needed a 72/86-330v start cap...BUT the start cap that came in the unit was a 243/292-165v..I asked the parts guy why, he said the wrong capacitor was installed..
    I got all the start components bought and installed...compressor is locked up.
    I’m wondering if the wrong start capacitor could be at fault..
    Thoughts
    Let's give nukes a chance.
    Virginia
    it ran for over a year ?
    Thats a hard call
    I guess when you swap the new compressor in just double check everything
    Could there be an oil return issue ?
    Jan 2010
    What's the compressor model number ?
    May 2005
    RST64C1E CAV 202. The run terminal on the compressor was burnt as well
    Jan 2010
    My bit is someone was there before you and installed the wrong cap.
    May 2005
    Nope, manufacture admitted they installed the wrong part per my 1st post.. they agreed the wrong start cap. Could take out the compressor..
    Jan 2010
    How does a electrical failure create a mechanical failure ?
    May 2005
    I’m here asking the same thing..but the manufacture agreed to me they we’re responsible
    Aug 2013
    Omaha
    A while back we installed 3 brand new scotsman 22inch 400Lb machines at a local college. The odd thing was they were all 208/230V machines even tho they were only small 400Lb capacity units.
    All 3, in 3 weeks had failed water pumps because someone at the factory put in 115V water pumps instead of the 208/230V ones. Factory covered it all tho in our case.
    Hopefully they do with you as well
    Sent from my SM-G975U using Tapatalk
