Results 1 to 13 of 13
    Sep 2019
    Communicating thermostat vs non for modulating furnace?
    Does anyone have a ball park estimate (or documentation/stats) about the cost savings of using fully communicating thermostat with a modulating furnace versus using a non-communicating thermostat on that same furnace? I understand that different manufacturers and specifics will come into play which is why I'm asking for a generalized answer.
    Aug 2009
    Beatrice, NE
    Savings will probably not change much assuming the Non-C stat will allow all stages of the furnace to run. It will be more of a comfort issue, the comm stat will allow full functionality of the unit the non Comm stat probably will not.
    Why do I get the feeling you want to put on a Nest and the dealer is telling you no?
    Sep 2019
    Well here is the deal.... I was about to buy a new furnace that was a two stage and I found one that was a holdover which was the correct tonnage and BTU for a really really good deal, $600 less than the one I was going to buy, plus was modulating. I have Nest currently and just want to know if I spent the $400 to get the correct thermostat and Internet link if I would make that money back over a period of time.
    Of course the modulating should be more efficient than the two stage anyway, even without the correct thermostat but just curious.
    Quote Originally Posted by BNME8EZ View Post
    Southold, NY
    NEST
    S
    U
    C
    K
    S
    Aug 2009
    Beatrice, NE
    The big question is if it will function with the Nest. Usually a Mod furnace needs the correct stat.
    Sep 2019
    Yes, I know everyone here hates Nest, I know it very well. The furnace is hooked up and runs really well, it doesn’t modulate all the time like it should because of the obvious Nest in the mix but it does have modulation on a profile during its cycle, something like starting at 30% working up to 100% dropping down to 50% etc. I know that if it modulates all the time, I will have a more comfortable house, but the savings are what I’m really interested in. Especially when it’s a $400 or more deal.
    Rochester, NY
    Multi stages or modulation is not for more efficiency it’s for comfort.
    Sent from my iPad using Tapatalk
    NEST
    S
    U
    C
    K
    S
    X2!!!
    Trash the NEST.
    Quote Originally Posted by wsudu View Post
    The NEST is junk because it causes more issues with equipment, known or otherwise, than any benefits it provides. It is also a data collecting device.
    What data does it collect?
    For whom does it collect the data?
    PHM
    Quote Originally Posted by pacnw View Post
    The NEST is . . . . also a data collecting device.
    PHM
    0% savings using a communicating stat over a conventional thermostat.
    Aug 2009
    Beatrice, NE
    PHM
    I'm told it has a camera and microphone, then the data is given to Playboy!
    What furnace? Most do not properly modulate without the communicating stat. Most won't modulate down on a regular stat (or irregular in the case of Nest). Trane starts about 1/2 way and increases as time passes, I think Lennox is similar. But as time passes, it should go down not up. Rheem's mod has 13 stages with the right stat, 3 with a standard stat. Rheem's Econet control is rather affordable compared to most and they've made modulating furnaces about twice as long as everyone else.
